Thread: 1.8 non-VVT - o2 sensor malfunction
    Chelmsford
    Default 1.8 non-VVT - o2 sensor malfunction
    Just started up and got an EML and P0136 registered.
    o2 sensor, bank 1, sensor 2.
    Am I right in thinking this is the sensor which screws into the upper side of the exhaust, just after the flexi joint?
    Chelmsford
    Oh, by the way, I just put a bottle of injection cleaner in the tank...
    Could this be causing odd readings on the lambda resulting in the EML?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    thats the one i would be cleaning up first..
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Yup the second one after the flexi. TBH I wouldnt even bother trying to remove it, most likely knacker up the flexi. Mine throws the same 0136 and 0036 codes weekly, does not effect the running or the mpg that I can see. I just clear it with my code reader. I will change it when the front pipe gives in.
    Jan 2008
    South Wales
    Hi,
    Looks like P0136 is a heater fault with the sensor. If you unplug the electrical connector for the Post-CAT (rear) sensor, you can test the heater circuit with a multimeter. There will be 2 wires the same colour on the sensor - measure the resistance between these 2 wires. Should be about 4 or 5 ohms. If the heater has failed, you will not get a reading as it fails open-circuit (element burns out). If the heater has failed, cleaning the sensor wont help, you need a new sensor. Looks like they cost about £35 for a part with correct plug.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Black wire, grey wire and two white wires,had the same problem on my old vec b Sri,ended up changing it
  1. Y22dth po340 camshaft position sensor malfunction
    By GHz in forum Engine & Drivetrain
    Last Post: 6th June 2018, 17:15
  2. Replies: 2
    Last Post: 24th June 2012, 02:11
  3. plz help,P0340 Camshaft Position Sensor Circuit Malfunction
    By bedo13 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd October 2010, 14:58
  4. Fault code 0340 Cam sensor malfunction
    By otto in forum Engine & Drivetrain
    Last Post: 28th June 2010, 13:55
  5. O2 Sensor Circuit Malfunction
    By marcdale in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2009, 21:21
https:www.vectra-c.comforumshowthread.php183113-1-8-non-VVT-o2-sensor-malfunction
Sensor vvt request post
bank 1 sensor 2 vectra c 1.8 p0136
