Thread: Radio Removal help
    Regular Member Rod C's Avatar
    Feb 2013
    Chichester, West Sussex
    Vehicle : Vectra 1.8 LS
    Trim : LS
    Engine : 1.8
    Default Radio Removal help
    Hi i have got a Parrot hands free to plug into the back of radio,it is an 03 vectra, I have removed the 4 grub screws but still cant see how radio is removed so i can wire it all up.
    PLEASE HELP
    Regards
    Rod
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    you need some double din removal tools.. cost a couple of quid or so from the bay.. but there may be some cheaper somewhere
    like this http://www.ebay.co.uk/itm/Vauxhall-O...item5653217d2b
    13 Post(s)
    You need to either use the official removal tools which poke down the holes left by the removed grub screws, or improvise and make your own from a wire coat hanger, or 4 small screwdrivers.
    Feb 2011
    Selby
    As above. Down the sides of the radio are four metal clips that hold it into the surround. By inserting the proper tools, coat hangers or something far enough down the holes you push the clips inwards, releasing their grasp and allowing you to then pull the radio out.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    So the technique is:
    Remove 4 grubscrews (where present)
    Insert removal tools until they are felt to 'click'
    Push removal tools 'out' (ie toward side windows) and at the same time pull the headunit toward you.... it may well be quite stiff if it's not been removed in a while.
    Once the headunit is almost clear of the dash, support the weight and don't pull the unit too far until you can see how much free cabling you have to play with.
    Feb 2013
    Trim : LS
    Engine : 1.8
    Ok Thanx I will try it with a piece of wire, I have just been to town and if I had read this before i went i would have gone to Halfords
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    Be patient when extracting the radio - sometimes these can be VERY tight in their cages.
    Assuming your's has never been previously removed, you should not have too much trouble,
    but I have struggled with some unts where the release plates have been bent out,and the release tools do no more than force the locking tangs into the wrong direction.
    Also - make sure you have the radio code / car pass before taking the radio out - for obvious reasons.
    13 Post(s)
    Thinking about it, if all the OP wants to do is plug in a parrot hands free to the back of the stereo, could he do it with the glove box removed and just reach around the back of the stereo without needing to take it out?
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    depending on his dexterity.
    It can be done by just removing the glove box.
    just be careful that you don't blow fuse number 12 by accidentaly shorting the glove box light on the metal dash support spars. ;-P
  1. Radio removal?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2011, 22:18
  2. Radio Removal
    By urbanfox in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2011, 21:56
  3. ****** radio removal
    By neilb1 in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2011, 21:56
  4. Radio Removal
    By Image2000uk in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2009, 23:26
  5. Radio removal
    By The-Bandit in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2007, 10:11
