Thread: 1.9 cdti 150 lumpy/surging when driving
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Engine : 1.9 cdti 150
    Mileage : 145000
    Default 1.9 cdti 150 lumpy/surging when driving
    Hi, can anyone possibly help/ advise.
    I have a vectra c 19.cdti 150 and has done 140k.
    When driving it runs fine at first but after a while the engine starts to run lumpy and feels as though im putting my foot on the brake ever so slighty and then releasing it. maybe i could descibe it as a kind of slow juddering feeling. (sorry there may be a better way of describing it but cant think at the moment ).
    I have blanked egr off and cleaned throttle body (last year), injector 3 modded last year, changed boost pipes. Alternator changed.
    Any suggestions and advice would be much appriciated.
    Thanks in advance
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Mileage : 145000
    Also just to add if I have the car at idle and then rev it slightly mabe only up to 1200 - 1500 rpm I can feel the engine judder and shake. But seems fine at normal idle.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Is EGR fully blanked, or the one with holes in it?
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Mileage : 145000
    fully blocked. cleaned boost vac pump filter too.
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Mileage : 145000
    sorry that should say fully blanked off.
    The problem is still there but is intermitant. The engine management/emmisions light is on so i removed the blanking plate to see if this would clear, and maybe sort the problem.Nothing changed.
    I've cleaned the vac pump filter cleaned egr and throttle body, changed all boost pipes checked air filter.
    Does anyone have any suggestions of possible fixes before I have to take it too the garage once again and loose more of my hard earned £££s.
    I know the obvious answer is get the fault codes read but i'd like to try all i can before surrendering to the steelers.
    thanks again
    wirral
    60 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sorry but don't understand why you'd want to throw money time an effort throwing parts at something when could go to local garage pay to get codes read an then at have a fighting chance at finding an sorting the fault
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Mileage : 145000
    Great!
    wirral
    60 Post(s)
    Trim : Basic
    Engine : 1.9
    It's worth investing in a handheld obd reader or a vauxhall specific one as its a great help to plug in pull a code an have a tough idea an what car thinks is wrong to them perform some tests.
    can be had for under 20 quid so pay for them self after 1 use
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Mileage : 145000
    Ok, thanks. Is there any particular one you'd recommend?
  1. lumpy 3.0 v6 cdti
    By Guss in forum Y & Z30DT Specific
    Last Post: 13th September 2011, 11:13
  2. 54 cdti surging and whirrling noise?
    By mr goose in forum Vectra C / Signum Troubleshooting
    Last Post: 14th April 2011, 13:11
  3. 2.2dti very lumpy idle-fine whilst driving tho?
    By Craig1985 in forum Engine & Drivetrain
    Last Post: 7th April 2011, 09:17
  4. cdti 120 - loss of power/misfire/surging
    By k12pc in forum Engine & Drivetrain
    Last Post: 22nd January 2011, 21:51
  5. Lumpy pickup 1.9 CDTi SRi 150
    By Jon Richards in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2008, 14:39
vectra 1.9 cdti idle surging
