Results 1 to 10 of 28
Thread: Vectra VXR factory map
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Vectra VXR factory map
    I promise this is my last VXR thread as I am still testing the water at the moment
    Looking at a few of the 255 VXRs I was wondering if the dealer would be able to upload the 280 map onto the car?
    When I first got my run around cdti it had been remapped and I took it to the dealer. They reverted the car back to the standard most up to date map for the sum of £30 quid so I wondered if the 280 map could easily be put onto a 255 meaning a super cheap (but very safe) remap
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yes is the simple answer mate
    South east
    Paul, are you sure? The 255 version was released first because the ESP system wasn't yet set up to handle 280 BHP, so in theory Vauxhall never created a 280 BHP map that would work with the 255's ESP programming. If that's the case John, you'll need an aftermarket map and not just a stock Vauxhall one to get the higher power.
    Jan 2006
    Dalriada
    I'm with rebellion here, pretty sure I've read on VXRo that it cannot be done..
    We're the original 255's not a different engine code to the 280's too?
    Sent from my iPad using Forum Runner
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Chance your arm bud with the dealer and see what they say.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Differences between a 250 & 280 models
    The block is the same - YES
    The plugs are the same - YES
    The turbo is the same - YES
    The injectors are the same - YES
    The intercooler is the same - YES
    The water radiator is the same - YES
    The cams are the same -YES
    The fuel pump is the same - Yes
    The ECU is the same - No
    The map is the same - NO
    The induction system is the same - NO
    Inlet manifold is the same - NO
    Apparently the ECU is different hence why they have both a different part no, however its still not know fully if the ECUs internally are different in any way. One thing is for sure though - if you want a VX map for a 250 or a 280 it comes direct from factory on the ECU itself !
    The CAMS are actually the same, the real difference is the VVT hydro pulleys which adjust the timing apparently
    The Inlet mani is slightly different to on the 280 model
    There is deffinately a difference in the airbox on a 280. but all seem to map to the same once the airbox hole is drilled (gives up to 10bhp).
    Glasgow
    A dealer can't remap a car even if a newer model did have more power. Never heard anything so ridiculous.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by byebyeitsagsi View Post
    Why not? Some manufactures allow there dealers to map cars with aftermarket maps (saab were a prime example) so why not a new oem map?
    Glasgow
    I believe the cylinder liners are different along with other minor internal differences.
    Glasgow
    Quote Originally Posted by Ziggy View Post
    If an individual dealer wants to be an agent for a remap company like Thorney or superchips that there own choice. A bog standard dealership like 9 out of 10 of them have no way of remapping a car unless they are an agent for an aftermarket tuner.
  1. vectra c mod list 'as it shuld have come out factory
    By Petiemc in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2013, 11:21
  2. My Vectra - Any way to find the original factory build spec ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2012, 09:33
  3. factory xenon not a vectra
    By DAVIDD88 in forum The 'Off Topic' room
    Last Post: 5th January 2012, 19:56
  4. Replies: 3
    Last Post: 24th January 2008, 16:20
  5. 52 Vectra SRi 2.2 with factory extras
    By SYMON in forum Cars for sale
    Last Post: 16th January 2008, 19:19
drilled airbox and remap on the vxr www.vectra-c.com
