Thread: Anybody on here a current vaux technician
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    Default Anybody on here a current vaux technician
    Had about enough of my current vaux dealers as everytime I go in there they just fob me off. Want someone to have a look at my breaks as after they point blank turned round and said do I know how to brake last time I took the car in.
    Just so you know what's happened so far,
    Car brakes completely failed and just vibrated when I put my foot down even when I re-applied although no wheels where locked.
    Took it in told nothing is wrong.
    Recently put my foot on the brakes again and now I've got a nice chip to the front bumper after the brakes went solid as if the vacuum pump had failed and rear ended my bros car.
    Could this all be down to the vacuum pump or is there a more serious issue that they are avoiding?
    Just want someone to look at the car that hasn't got a stake in it if I send it back If you know what I mean, get the feeling they keep ignoring it so they don't have to take the car back. Because as far as in concerned its unfit for purpose and not safe on the road :-/
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    had a diesel 150 a while ago brake would go hard after been used a coulple of times turned out to be servo itself at fault
    Aug 2012
    Hartshorne
    Trim : SRI
    I figured it was either a servo fault or master cylinder fault as it only does it randomly and sometimes its soft at the top but like pressing a brick from halfway down. :-/ similar thing?
    Regular Member Exclusive BV's Avatar
    West Midlands
    why would they be fobbing you off, did you buy it from them?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What tests have been carried out?
    Aug 2012
    Hartshorne
    Trim : SRI
    Not sure they just said compute shows no faults and they can't see anything with the hand break or wheels themselves. They've said nothing about the servo or master cylinder.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by owen_999 View Post
    That really p****s me off about main dealers now. Had a few instances where they have fobbed me off with that one, and when I've told them to manually investigate I get the same answer "sorry sir the computer missed that one"....
    If the brakes have completely failed like that, there's obviously a major fault somewhere.....
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    So they've not actually offered to go on test drive etc?
    If I can't find a fault I always offer for customer to take me out and see if they can demonstrate fault.
    in your case it may need to be in a more controlled manner but still.
    Could be a partial failure of servo diaphragm.
    or failing vac pump
    i would apply vacuum to servo and see if it holds ok
    Aug 2012
    Hartshorne
    Trim : SRI
    That's what I would of thought, they just take it off me and tell me there is nothing wrong at the end of the day. It's not even a constistant fault it just randomly happens. Has only happened to me twice,
    The first time I had just started the car and was flying down the road to work and was braking (or trying to) brake quiet heavily for a roundabout when it first juddered and didn't stop.
    This second time I was only doing about 15mph when I went to put the brakes on to slow for a corner and this time it felt as if the pressure just disappeared from the pedal and there was no brakes again. :-/ I can't think of anything common between the two occurrences of if to be a cause. :-/
  1. My current set up...
    By danBoy in forum ICE Gallery
    Last Post: 4th July 2009, 12:26
  2. my current vectra
    By steven77 in forum Non Vectra C/Signum Album
    Last Post: 6th March 2009, 02:09
  3. My car in its current state...
    By danBoy in forum Quick Photo Album
    Last Post: 27th August 2007, 21:20
  4. current account
    By lborob17 in forum General Chat
    Last Post: 5th February 2006, 15:09
