Thread: Trying to change alternator and am stuck!!
Hybrid View
    Mar 2013
    Liverpool
    Trim : LS
    Engine : 2.0 Dti
    Year : 02
    Default Trying to change alternator and am stuck!!
    Hi Sorry if this sounds dumb but I was following one of the how to's on changing the alternator it was not for my specific model but from the pics it looked familiar. I got all the way to removing the bolts from the alternator the top one came out no probs but the bottom one is to long and hits the chassis before enough of the bolt is clear of the bracket. How do I get it out do I have to drop the engine out or something? My car is a 2.0 DTI on an 02 plate any help would be much appreciated.
    Dal5band
    Guest
    Just looked at you know what ! - it says remove a few things so you can swing the alternator out to get to the bracket mounting bolts. Then remove the bracket mounting bolts to the engine block, then remove the alternator complete with the bracket.
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    doh ....lol
    Dal5band
    Guest
    PS The above was for an early 1.8 petrol (Z18XE) by the way - may work for your DTI
    Mar 2013
    Liverpool
    Trim : LS
    Engine : 2.0 Dti
    Year : 02
    Ahh ok the guide I was following was for 1.9 cdti and there was no mention about removing the alternator bracket aswell.Thanks will try again today in the daylight
    Mar 2013
    Liverpool
    Trim : LS
    Engine : 2.0 Dti
    Year : 02
    No I give up will have to take it to a garage to get it fitted, the bottom bracket is part of the engine mount so I cant see ho to remove it with out droping to engine.
  1. Change alternator - 2,2 147 hp
    By zafira in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 21:48
  2. need help on how to change my alternator.
    By bigjoe8707 in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2012, 13:49
  3. vec c 1.8 alternator change
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 13:20
  4. alternator change
    By glasgowrob in forum Engine & Drivetrain
    Last Post: 1st January 2010, 12:58
