Results 1 to 10 of 15
Thread: decat pipe help
    Regular Member franko's Avatar
    Aug 2012
    goole
    Default decat pipe help
    Just got a decat pipe for my 1.9 cdti siggy 120 but ineed to know if mine has a diesel partical filtter or not if not my pipe won't fit .the pipe I've bought comes straight of the turbo if that helps and lastly what sort of gains am I goin to get thanx
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    Quote Originally Posted by franko View Post
    I though all signum and estates had dpf...
    The other way to tell is the plate on the drivers door but I can't remember which code is dpf and which ain't....
    If it says 1.20 on the plate then you don't have dpf if it says 0.50 then you do!
    And I believe the 120hp codes are 1.30 haven't got dpf and I assume 0.60 and you have?
    Aug 2012
    goole
    Don't think so pal I've got the haynes bible out and it say that some do and some don't
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    I'm just remembering of the top of my head from when I checked mine! Although I wouldn't take a Haynes manual as gospel lol there usually awful!
    The code on the drivers door plate should work though :-)
    I just thought all signums, estates and autos had dpf but the others usually don't
    Aug 2012
    goole
    Found a sticker about half way up the drivers side door piler and the only number that look s simeler is 0.50 is this the right number
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    Yeah that's the one I believe that means that you have got dpf
    Aug 2012
    goole
    Cheers mate that's a big relef what will I gain by putting this on and is it an mot fail
    Full Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Are you referring to the precat or the main cat which your de-catting? Perhaps a link to the part you have purchased?
    Aug 2012
    goole
    No link I'm afraid but I know that it comes straight out of the turbo and conects to theflexie pipe section if I'm right siggys have two cats on them so its the first cat I'm decating starting from the engine
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    That's the pre cat then :-) the second cat will be in the middle section underneath your car! I think for best results you need to lose both!
    Personally I'd probably get the dpf out as well because they seem to be ticking time bombs waiting for a failure
  1. Decat pipe fitting?
    By Adam8220 in forum Diesel Engine related
    Last Post: 21st July 2012, 18:09
  2. decat pipe
    Last Post: 28th March 2012, 20:34
  3. flexi pipe fix and decat
    By james walker in forum Vectra C / Signum Troubleshooting
    Last Post: 15th September 2011, 22:36
  4. decat pipe wanted ... bad:)
    By vectraturbocal in forum Styling
    Last Post: 9th September 2010, 07:37
