Thread: Miss fire woes GSi 3.2
    Regular Member DanBristol's Avatar
    Jan 2013
    bristol
    Default Miss fire woes GSi 3.2
    ****ed off to be blunt ! diagnosed misfire on cylinders 4 & 2 high mileage 200,000 also running lpg
    Just had the new coil pacs fitted and new plugs yet its still showing up codes for cylinders 2 and 4
    The mechanic says it could be a head gasket or a valves gone due to lpg ?? ...what you guys recon ? is there anything else to try before having the head off (please dont let it be that )
    Dan
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Silly question, but is it still misfiring after a new coil pack, or its just showing the codes for a misfire after the new coil pack?
    Jan 2013
    bristol
    Im yet to pick the car up im just going on what the mechanic told me over the phone, id of thought he would of re set the codes. it is still misfiring after the packs and plugs...mostly on no 4 slightly on 2 ????
    ps eml light comes on usually at idle
    Jan 2013
    bristol
    Two quick ones ..... Does the 3.2 V6 have hydrolic cam followers ? and if so could one be causeing a misfire and pinking if it was gumbed up ?
    dan
    Jan 2008
    South Wales
    Hi,
    Is the misfire present on Gas and Petrol? If you force the car to petrol and it does not misfire, the issue is with the LPG system.
    Can the garage perform a compression test on the cylinders? This should give some clues before taking the head off. If compression test is ok, should prove valves and head gasket are good.
    Jan 2013
    bristol
    Hi,
    The misfire is on both petrol and lpg, its not severe just a lumpy idle and enough for the eml to come on.
    Aparently you can only do a manual compresion (turning over by hand) test on this 3.2 V6 motor as you have to have all the plenem chamber off to get at the spark plugs
    The cars done 200,000 miles and has been well maintained drives great but i cant warent spending a grand on it getting the heads done .. my next move is a sniff test and going to try a terraclean !!
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    If you think the head gasket has gone, I wouldn't bother getting the current one machined. Just pick one up from a Vauxhall breaker, check it for flatness across the head and throw it on with a new gasket kit.
    Jan 2013
    bristol
    Thats another option .. cheers
  1. 1.9CDTI (120) Hesitating / Miss Fire
    By pshankland in forum Engine & Drivetrain
    Last Post: 20th June 2012, 12:50
  2. Miss-fire, judder, low tick over????
    By Mattle40 in forum Engine & Drivetrain
    Last Post: 14th February 2012, 14:46
  3. vec b miss fire
    By daddyjay in forum Engine & Drivetrain
    Last Post: 25th September 2011, 19:26
  4. signum splutter and miss fire
    By basemanlee in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2010, 20:02
  5. Miss Fire has gone!
    By Maverick in forum Diesel Engine related
    Last Post: 12th June 2009, 09:02
