Thread: Front Wheel Bearing Signum
    Chester
    Default Front Wheel Bearing Signum
    Hi All,
    Ive got a rumbling soung coming from the front o/s, well its coming from that area anyhow, its like a rumble sound. Not loud but annoying, I think it maybe a wheel bearing any wondered if they are hard to replace as it appears you replace the whole hub complete. I have seen one on ebay for £65, easy job?
    as per my other post to you in the main section....
    http://www.vectra-c.com/forum/showpo...7&postcount=17
    it's not hard to do,and that is a great price for the hub unit, they should be 120 odd quid from VX, so it's a pattern..but if it cures it......
    Nicking Ya Dinner.
    Before you go stripping it and buying new parts, do this...
    1 - Check Tyre pressures
    2 - Check pads for wear
    3 - Check cv boot and do a full lock test to check it isn't clicking
    If all of this proves not to be the cause then go ahead and replace the bearing. hth
    Chester
    [quote=VauxVeteran;226098]Before you go stripping it and buying new parts, do this...
    Thanks for the advise, I have done 1 and 2 but how do I check the cv boot? I take it a lock test would mean putting steering on full lock left and then right and having someone listen for clicking? The dealer did replace the track rod ends and checked for any play in drop links but the noise still persists, gets worse after bout 5-10 mins driving friom cold.
    Nicking Ya Dinner.
    Yep, thats it, full lock, if anythings worn it will clack.
    What brand of tyre do you have? if they are different on the back to the front, switch them around and see if the noise migrates with it. Some tyres do naturally hum depending on the compound used.
    Chester
    Ive got michelin primacy on the fronts and goodyear nct5's on the rear. I will try swapping then and see what happens. Thanks for the help.
    Chester
    well i switched my tyres around and discovered that the droning noise from the rear has disappeared, and now is at the front. I thought that i had road noise resonating in the back. Thats a good result so have just had 2 new goodyears nct5's on the front. But there is still a rumble kinda wind noise coming from sumwhere, gunna have to let someone else drive while I sit in the back and try and locate it. Its really getting to me this rumble, its a hollow rumble sound if that makes sence.
  1. Tie rod and front wheel bearing!!!
    By scotty82 in forum Suspension, Wheels & Brakes
    Last Post: 30th March 2012, 19:04
  2. front wheel bearing
    By paulb70 in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 20:15
  3. Front wheel bearing/hub
    By daviek in forum Parts for sale
    Last Post: 9th April 2010, 16:55
https:www.vectra-c.comforumshowthread.php18305-Front-Wheel-Bearing-Signum
