Results 1 to 10 of 19
Thread: How to change boost hose? 1.9 CDTI 120
    Dec 2012
    Midlands
    Default How to change boost hose? 1.9 CDTI 120
    Hi Guys, for a couple of months I've been having a bit of a 'whoosh' noise as I accelerate and a lumpy idle. I believe that to be linked to a hole I found in the hose marked below (not my car).
    I have bought a replacement silicone hose to switch with it (for £15) and was wondering if there was a guide to getting it replaced? Its pretty cramped down there and I don't really want to be messing around taking bits off I might not need to.
    So, anybody done it and want to share their experience?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    That's a 150 engine, (never seen a 120 engine bay) are the boost hoses in the same place?
    Incidentally, that hose is easily accessible with the bumper removed (which in itself is a 5 min job).
    Wirral
    6 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Take out the headlight, gives you much more access to the hose clamp. Then pull off the airbox air feed pipe. It's just a push/pull fit thing. Word of warning too, the Vauxhall ones are pants so nip to Halfords or the local auto factors and pick up some of the hose clips. 55mm or so rings a bell. Should be able to eyeball it pretty well.
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    I've got the full silicone boost set in my garage waiting to be fitted but I keep bottling it haha!
    Dec 2012
    Midlands
    Cheers for the tips guys. Didn't realise it was a 150 engine but I can concur those pipes at the front of the engine are the same as on my 120. Hopefully get on it at the weekend then.
    Should this improve my lumpy idle from cold?
    Dec 2012
    Midlands
    Quote Originally Posted by Ozyboyross View Post
    I'm a "if it aint broke don't fix it" kinda guy too, hence I only bought the 1 hose.
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    Quote Originally Posted by ficosaneil View Post
    I've got a leak somewhere and I figure do it all once and not have to worry coz silicone should outlast the car lol
    I'm just a bit nervous of touching anything engine related or bumper removals coz I've never done it before lol
    Dec 2012
    Midlands
    Quote Originally Posted by cont1204 View Post
    Just been and had a look, I reckon that'll do the trick. Just the 2 fixings on the top I assume? Should'nt take too long. Cheers.
    Lancashire
    Trim : XP1
    Mileage : 66000
    You need to drop the bumper (on that side) to get access to the bottom bolt for the headlight.
    Dec 2012
    Midlands
    Ah right, any simple instructions where I need to go for the bumper fixings?
  1. Boost hose
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 09:58
  2. CDTi top boost hose close to bolt
    By lee gsi in forum Engine & Drivetrain
    Last Post: 31st August 2010, 18:53
  3. boost hose
    By leeroy in forum Diesel Engine related
    Last Post: 30th April 2010, 08:13
  4. Silicone boost hose for DTi?
    By fikse in forum Diesel Engine related
    Last Post: 6th February 2010, 17:55
