Thread: Hard steering
    Regular Member BBMadness's Avatar
    Apr 2012
    Merthyr Tydfil
    Default Hard steering
    Got an issue with my steering that has developed over the past 3-4 days
    Changed my tyres around and went for a country road drive
    Following day steering very stiff hard and lumpy
    Changed tyres back round last night and still just as bad if any thing getting worse
    Any suggestions
    Regular Member Keif's Avatar
    In the Garage
    Is the power steering fluid the correct level?
    Apr 2012
    Merthyr Tydfil
    Yes power steering fluid at correct level
    Oct 2012
    uk
    Hate to say this m8 but you will probably need to replace the pump I have just had to do mine. got worse then packed in altogether over the course of a week
    Apr 2012
    Merthyr Tydfil
    May i ask how much it cost you roughly and was your symptoms exactly the same??
    Apr 2012
    Merthyr Tydfil
    Is it a job that can be done yourself
    Oct 2012
    uk
    Sorry if too late m8 having internet issues at the moment so just got back on, got a second hand one for £40 easy to change aswell, take off front bumper and its self explanatory once you see it just a few 10mm nuts and a 13mm nut to undo, one pipe to slip off and the other was 19mm just use a dish of some kind to catch the fluid thats leaks out. I had three plugs to unplug some may have four but thats about it took 15-20 mins and was done. Remember to fill it back up with fluid before you bolt it back up makes it easier. Mine was getting harder to steer then would cut out completely weird thing was if I unplugged one of the plugs it would kick back in for a short time, but then that stopped working too.
    Apr 2012
    Merthyr Tydfil
    On further investigation today it was the fact that the pump was running dry
    Filled the pump with fluid and hey presto power steering was back
    Oct 2012
    uk
    Good news there m8 lucky for you then eh!
    Apr 2012
    Merthyr Tydfil
    Oh yes definitely
    Was a process of elimination
  1. Insignia Anyone know how hard it would be to fit this?
    By Mark Evison in forum Insignia car chat
    Last Post: 8th April 2012, 00:21
  2. Replies: 6
    Last Post: 13th March 2011, 10:47
  3. Steering groanon hard right turn
    By steeley7 in forum Suspension, Wheels & Brakes
    Last Post: 9th February 2010, 21:27
  4. Power steering hard at low revs? what the..
    By cjporter in forum Handling & Braking
    Last Post: 20th November 2009, 15:56
  5. Steering rack end, easy or hard to do?and gearbox woes!
    By sri andy in forum Engine & Drivetrain
    Last Post: 13th May 2009, 19:48
