Thread: Ecu reset or reprogram after fitting a different maf?
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Ecu reset or reprogram after fitting a different maf?
    Will the ecu need a battery disconnect reset or anything after fitting a new second hand maf?? I read on google the ecu needs to learn of a new maf or is this rubbish? Will a battery reset do any harm anyway? Just to get rid of the maf eml codes? Thanks
    Sep 2012
    Stoke on Trent
    Engine : 1.9 CDTi 150 Z19DTH
    Hi. I know that there is an option for MAF adaptation on diagnostics scanner but only for certain models such as 1.9 CDTi
    but there isnt one for DTi models
    I personally would just change it as you do with most cars, but it is only my opinion.
    Sep 2010
    Leeds
    Right ok, thanks for reply, will just change it and see how it goes. I just read your car ecu will be used to driving lean on fuel mixture and will carry on to do so unless it learns there is a different working maf. But i know you carnt always believe what you read on internet.
    Sep 2012
    Stoke on Trent
    That is definitely true.
    Sep 2010
    Leeds
    Is there anybody with 1st hand experience?? 1.8 petrol? Thats fit there own maf?
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    I changed the MAF on my old LS (Z18XE) when I was fault finding an issue. Just plugged in the replacement one and away it went. Think I reset the fault codes I had popping up at the time, but that was it.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Just clear code and fit new one.
    dont do any adaption using diagnostic on a second hand maf as the hot wire will already have a fine layer of dirt so will give a miss reading.
    Sep 2010
    Leeds
    Cool, so will the ecu automatically readapt to a new working maf on its own?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Trim : ES,Panoramic Roof and Power Mirrors
    Engine : 1.8 iVtec
    Mileage : 67500
    Yes. It will update the new values as it goes.
  1. reprogram key
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2012, 21:09
  2. EGR Reprogram
    By tinytiger in forum Vectra C / Signum Troubleshooting
    Last Post: 9th September 2011, 17:56
  3. Anyone recommend a dealer to reprogram my CID
    By acorndave in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2010, 19:46
  4. How to reprogram a key fob
    By lukesignum in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2010, 11:39
  5. bsr ppc reprogram ??????
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2008, 23:10
https:www.vectra-c.comforumshowthread.php183031-Ecu-reset-or-reprogram-after-fitting-a-different-maf
vauxhall vectra reprogram
vauxhall insignia ecu reset
Reset ecu vauxhall insignia
vectra c 1.8vvt maf
z18xe ecu reset
z18xe maf reset
z18xe reset ecu
how to reset ecu vauxhall insignia
vauxhall vectra c ecu reset
how to reprogram opel vectra ecu#scso=uid_WHMicQAC_YMKFO2DGAZHmA_0:232
opel z18xe maf adaptation how to
vectra c 1.6 ecu
reset adaptation z18xe
corsa c maf reset ecm
vauxhall new maf sensor ecu adaptation
