Thread: Lumpy idle
    Sep 2011
    essex
    Default Lumpy idle
    Hi I hope you can help me again,you lot have got me out of the poo a few times in the past, I hope you can do it again. The car is a150cdti and the problem is that when hot or cold when idling every now and then the idle will become lumpy only slightly ,but enough to notice ,then lately when you accelerate to overtake the car will miss and hesitate , the egr and map sensor have been cleaned. Any ideas? Cheers.
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    Could be the third injector issue that alot of 150s have.... There's a how to on here which shows you how to repair it! Kits about £15 on eBay and a bit if soldering from what I can tell
    Sep 2011
    essex
    Forgot to say hashed all 4 new plugs fitted about5 months ago, thanks for reply though.
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    Quote Originally Posted by nigelhamilton45 View Post
    Plugs or injectors? Two different things....
    Sep 2011
    essex
    The wiring plugs on top of the injectors .
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    Sorry mate I weren't sure if you meant glow plugs :-)
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Mileage : 66000
    A "cleaned" EGR doesn't necessarily mean its not at fault, to test it, blank it temporarily and see if the problem persists - quick job to slide a blanking plate in to test.
    Sep 2011
    essex
    Thanks for help will try this and let you know.
  1. lumpy idle 2.0 turbo
    By tecg in forum Engine & Drivetrain
    Last Post: 14th December 2011, 21:21
  2. 3.2 lumpy idle update
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 9th August 2011, 14:59
  3. Lumpy Idle + 1Gal/PH
    By Homer in forum Engine & Drivetrain
    Last Post: 4th November 2010, 22:16
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. 3.2 v6 Lumpy idle!?!
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 13th August 2008, 12:24
