Results 1 to 10 of 23
Thread: Cold starting problem continues!! Need Help!
    Jan 2012
    Doncaster
    Default Cold starting problem continues!! Need Help!
    2005 vectra cdti 150. 72k
    So about a month ago I suddenly started having trouble starting the car from cold.. I wait for the coil light to go out (sometimes repeat a couple of times before starting) and the car struggles to fire up.. Verry lumpy idle almost sounds like its knocking.. But once I give it a bit of accelerator a big cloud of smoke comes out the back.. The idle settles down and the car runs fine with no problems.. It also starts normally once warm and shows no other symptoms while driving apart from maybe a slight variation of revs on idle (hardly noticeable) no warning light are presented.
    To eliminate some possible causes here are the fixes I have recently done to the car...
    new glow plugs fitted.
    egr replaced.
    boost pipes replaced.
    mass airflow metre replaced.
    boost control sensor replaced.
    injector wiring upgrade connectors x4
    also I have never replaced the battery so nothing to do with wrong battery.. But could possibly be time for a new one???
    im starting to lean towards the injectors them selves but want to exhaust all other avenues before taking it to a garage.
    this is quite a specific problem and iv not had any luck searching the boards for an answer so I could do with the help of the forum now.
    Any suggestions????
    Aug 2012
    berkshire
    have you changed the fuel filter and/or checked to make sure its not leaking?
    Jan 2012
    Doncaster
    I never thought to check it as it runs fine once started.. But I will try that next. Do you think that could cause these symptoms? Would a leaking fuel filter cause starting issues?
    thanks for the quick reply!
    Jan 2012
    Doncaster
    Mpg is still good also on long journeys as I regularly drive over 400 miles every couple of weeks.
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Have you checked to see if a voltage is getting to the glow plugs? It does sound like they are not working.
    Jan 2012
    Doncaster
    What do I need (tool) to check the voltage? And how would I go about checking it? Sould like a good place to start.. If it is low voltage to the plugs what would I need to replace? Battery?
    Jan 2012
    Doncaster
    Any info on replacing leak off pipes on the injectors? Are they a special part or can I buy silicone pipe to replace them with?
    Dec 2010
    London
    5 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Unplug coolant temperature sensor and see how it starts
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    ....colour of smoke when its cold and you start it?
    Ours does pretty much the same dance when starting from cold and the smoke from ours is kind of black with some blue in it.....look for the blue! I am thinking with ours it is the valve stem seals leaking during the night as thru out the day after the first start it is fine.
    Other things to check are.....inlet manifold operation and the glow plug ECU/controller, I have tackled the inlet manifold with excellent results for the power issues but still have the similar problem to yours so next on list is to test the glow pre glow plug module.
    Feb 2012
    sheffield
    Mileage : 140,000
    Quote Originally Posted by troutybrown View Post
    Hi,
    where is this sensor please?
  1. Starting problem with z19dt engine from cold.
    By 123rado in forum Engine & Drivetrain
    Last Post: 20th February 2012, 23:15
  2. cold starting problem
    By iansfocus in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd February 2011, 16:54
  3. Starting in the cold
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 22:15
  4. Bad Starting From Cold
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 7th October 2008, 11:48
