Results 1 to 10 of 11
Thread: Right...... I'm lost.
    Jan 2013
    Engine : 2.0T
    Default Right...... I'm lost.
    I'm totally new to all this, my last car got washed on average maybe twice a year and never by my own hand, I'll even admit to having put her through an automatic wash once or twice (I know, wash my mouth out and say 10 Hail Marys).
    Well I've recently bought a Signum, and for the first time in my life I have a car which I actually like the look of and want to make sure she looks her best.
    At the same time, I'm not going to be showing her or anything and I don't have time to spend hours every weekend cleaning.
    I have therefore been lurking this forum in search of the happy middle ground which will see me driving a car which is above average in the shineyness department while not spending every waking moment polishing.
    The reason for this thread is to check that what I think I have learned from you good folks is correct, and to ask for some advice re products to use. Here goes:
    So my thinking at the moment is to do a serious and probably fairly time consuming full wash and wax ~ twice a year (I'm thinking Spring and Autumn), then if I've done it well enough and used a quality wax the washes in between should be easier to get back to a nice finish.
    So here's what I think I need to do for the major washes:
    1. Wash car using two buckets and a wash mit (maybe two?) and normal car shampoo. Dry with microfiber towel.
    2. Use a clay bar to remove stuck on contamination from paintwork
    3. Wash and dry car again (necessary?)
    4. Polish car with something like AutoGlym SRP (suggestions welcome)
    5. Seal paintwork with wax coat
    6. stand back, admire now beautiful Signum, take photos and post on vectra-c!
    Thats fine, I think, but that's going to take a long time so what do I need to do in between major wash/wax sessions to keep her looking at her best? just wash, or is there something else I can apply relatively easily and quickly to keep the finish looking good for longer?
    Will the above process have a good chance of making my poor 54 reg Siggy's slightly neglected paintwork look good, or is there something else I should be trying. She has got her share of swirl marks, presumably from inexpert cleaning in the past.
    what products would you recommend at each stage to someone looking for a decent finish without breaking the bank?
    thanks in advance!
    Jan 2013
    Engine : 2.0T
    if it makes any difference to the product suggestions, my Siggy is dark blue
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    Remove 4 and 5 and replace with Autoglym ultra deep shine. Its a polish and wax in one and gives impressive results. In between just use Autoglym bodywork shampoo as that leaves a film on the paintwork anyway or use a quick detailer spray afterwards and use it like a wax
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Or pay someone to do it while you're at work
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    If you carry out the above cleaning twice a year mate ,but spend a good day on it,car will require just a top up wash and wax and perhaps a spot of de tar spotting in between to keep it up too sparkling,oh and by the way i highly recommend autoglym products throughout but ,wet n black for tyres, lasts for ages and best tyre dressing I've tried by far
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Year : 2015
    Mileage : 3,200
    Quote Originally Posted by Mark-R View Post
    Thats cheating
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    LOL but saves you time lol
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Year : 2015
    Mileage : 3,200
    Only way you will get swirls out will be with a machine polisher though. If you want to have the paint up to show standard you will need a full correction then its just a case of following the steps above. People on here do machine polish might be worth asking in your region section and see if anyone local can help you out.
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Quote Originally Posted by Mark Evison View Post
    I went the other way, lol.
    I found UDS gives pretty good results when used in conjunction with other products. However, on its own or as a LSP, doesn't protect anywhere near long enough. It also leaves an awful lot of white powder residue, especially if you get it in any nooks and crannies. SRP, with it's new formula, is much better in that respect and seems to be better at polishing, too.
    PBBH on top does a far better job of filling and giving it that wet, oily sheen and then I top it off with Colli915. I find that even a single coat (I try to get 3 coats in total on) of 915 gives much longer lasting protection than just UDS.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    No point in drying prior to claying, and yes rewash after claying, then dry. Then SRP and a wax. You can then just need to continue with a good hand wash routine and top up the wax monthly.
  1. Lost a DAM Hub cap!
    Last Post: 4th May 2012, 20:05
  2. lost.....do i need new ecu?
    By lilangel in forum Vectra C / Signum Troubleshooting
    Last Post: 21st May 2011, 20:35
  3. Lost
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 24th June 2009, 08:19
  4. lost 4 box set
    By xrken in forum General items for sale
    Last Post: 13th May 2009, 22:05
  5. Lost
    By thegoldenbullet in forum General Chat
    Last Post: 27th March 2007, 01:54
