Thread: 3.0cdti Air intake
    crook
    Default 3.0cdti Air intake
    Will car breathe better (cold air)if plastic cover which is blocking air intake when bonnet is closed is removed ?
    crook
    anybody ??
    Come on, give us more than 2 hours to respond, some people on visit once every few days...
    If you want to compare, simply unclip the grille and remove
    Personally, it won't make difference as the air volume will be the same
    Equally a higher speeds the air will be slightly more turbulent (as the fascia removes this) and so may make it worse...
    If you want to improve the air intake then add an additional channel so that it is fed from both sides of the grille (although you will need to modify the grille)
    crook
    Cheers.. never thought of removing grill
    Seen some threads where people have fitted a separate cold air feed,just space is quite limited on these babys
    Quote Originally Posted by jodiexii View Post
    Very much so
    When my local mechanic looked at "Who in their right mind shoehorned that engine into there"
    If you do fit an additional air feed, make sure it is not below the existing one, as you don't want to be sucking up any water...
  1. Help Please - 3.0cdti
    By renodci in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd March 2013, 16:10
  2. 3.0cdti - anything I should look out for?
    By renodci in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2012, 13:09
  3. 3.0CDTI - want one!
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2010, 19:13
  4. 3.0CDTi de-cat
    By Celes in forum Diesel Engine related
    Last Post: 27th February 2010, 01:53
  5. Looking to get a 3.0cdti
    By sidvish69 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 19:58
