Results 1 to 10 of 17
Thread: Temp Gauge not working - temp sensor - thermostat? help!
    Mar 2013
    reading
    Trim : sri
    Engine : 1.9 cdti 150
    Default Temp Gauge not working - temp sensor - thermostat? help!
    Hi,
    Recently bought a car from auctions, and i have no history of problems it has
    Temp gauge doesnt move at all no matter how far driven.
    Noticed when engine cold, there is a flow through the header tank, and ran for 5 miles, felt pipes, red arrow was hot but had no problems holding it for any length of time.
    The Yellow arrow, was stone cold.
    Then i had a route round, and found a sealed temp sensor, genuine vx part.
    Could this be the problem with what i have described?
    Jan 2013
    Hartlepool
    The yellow arrowed pipe is your air intake into the throttle body. Air from the intercooler so should be cold. Mostly like reason would be your thermostat, check the sticky post on here and the how2 for DIY replacing. Under £40 on ebay.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Could it more likely be a faulty thermostat
    Mar 2013
    reading
    Trim : sri
    so the temp sensor i found in the glovebox, the one on the car at the moment couldnt be the problem?
    Engine : 1.9 CDTi
    Its common for them to take ages to heat up.
    And as the guage doesnt start reading till 70 Degree's you might not see it it move.
    What head unit do you have as the CD70 has hidden menus where you can see the real temperature.
    Mar 2013
    reading
    Trim : sri
    Quote Originally Posted by lee gsi View Post
    i drove 190 miles with it, and it didnt budge!
    cd30 unit
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If there was some temp reading when hot and static, which dropped when moving I'd go straight for dead stat.
    No reading under any circumstances and I'd be thinking there's possibly no signal getting to the gauge. The reason though... well there I'd be looking at a Computer Based Application to narrow down what works and what doesn't.
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    how do we access this hidden computer bud?
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Testmode on CD70 type headunits (ie not the older single DIN headunits):
    Press and hold SETTINGS until your hear a bong (around 5 secs)
    Press BC, Audio, Nav, Sound as appropriate to scroll through data pages.... to show all manner of interesting data.... including coolant temp. No coolant temp - dead sensor (or break in the line).
    Mar 2013
    reading
    Trim : sri
    that didnt work on mine!
  1. fuel and temp gauge not working
    By hovis007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 19:35
  2. Thermostat or temp gauge or nothing?
    By mrpoochie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th March 2012, 12:11
  3. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  4. Engine temp gauge not working ???
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 21:36
  5. how much will it cost to change thermostat for temp gauge?
    By Ridah in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 11:51
temp gauge not working 08 vectra
vectra c temp gauge not working
vectra c temperature gauge not working
vectra c coolant gauge reads cold sensor reads 140°
vectra c temperature gauge problem
vectra 3.0 v6 engine temperature gauge not working
vectra diesel temperature gauge on cold
