Thread: Buying advice
    Feb 2013
    Kent
    Trim : Sri
    Engine : 1.9 cdti
    Mileage : 11000
    Default Buying advice
    Looking around at vec/signum I have been looking at the 1.9cdti engine, my budget is around £3500 and my only other real requirements are trip computer and cruise control which seem to be pretty standard on the ones I've viewed so far.
    I would like to know what I should be looking out for, I have read about dual mass fly wheels being a problem any other common faults and how best to identify them pease.
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    In order of failures on my car:
    DMF, rattles, clutch probably or should be changed at the same time (my cars was)
    Rear tyre wear on insides
    Wiper motor, only works on high speed, does not self park
    EGR valve, light on dashboard
    Alternator, battery light on dashboard, battery not charging
    Inlet manifold on 150 version only, apparently the on my car it is failing but it is still working and the car feels OK
    DPF, apparently not yet (touch wood) had it fail
    Others:
    CAM belt change between 70 and 100K
    Regular Member conman's Avatar
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Any of the Sri models come with cruise control and all the other stuff like on board computer with trip counter etc. I'd go for something with a timing chain instead of a belt but that personal preference and not sure about the newer models but my 02 plate 2.2 dti has a chain and just get the pulleys checked from time to time. You should get a nice 07 or 08 for around that price, just make sure when you test drive get it onto the motorway and speed up to over 80mph to make sure it's not kicking into limp mode. The other guys on here will probably give you more info as I'm new to the Vectra myself and still finding out bits and pieces on my own car
    Feb 2013
    Kent
    Trim : Sri
    Engine : 1.9 cdti
    Mileage : 11000
    Thanks for the answers guys, not seeing much response on this though. Have posted in the right place?
  1. Need advice on buying a GSi
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2011, 19:33
  2. buying advice
    By astra_baz in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 04:46
  3. Buying advice please!
    By moorlander in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2008, 15:47
  4. 2.0T buying advice
    By pricey in forum Petrol Engine related
    Last Post: 14th August 2007, 15:20
  5. a bit of advice when buying a car
    By pogo in forum General Chat
    Last Post: 21st June 2007, 09:48
