Thread: Drop links & ARB Bush
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Mazda 6
    Trim : SE L Lux Nav+
    Engine : 2.0 Skyactiv-G
    Year : 2019
    Default Drop links & ARB Bush
    I'm looking at replacing my drop links and arb bushes, wondering are these the correct ones for my car (Facelift 1.9CDTI Hatchback)
    Front drop link
    http://www.partsforsaabs.com/product...oducts_id=4013
    Front arb bush 25mm??
    http://www.ebay.co.uk/itm/Vauxhall-V...item589c863fcf
    Rear arb bush (which size there are 4 to choose from 16-19mm)??
    http://www.ebay.co.uk/itm/Vauxhall-V...item20cf7dfe50
    For the rear drop links i think genuine vx ones as i can't find uprated ones and pattern ones may not be good.
    Thanks.
    Nottingham, emec#7
    Vehicle : Mazda 6
    Year : 2019
    Anyone?
    Jan 2006
    Dalriada
    My rear arb size was 19mm on my facelift turbo, but I'm afraid I don't know what size yours are..only way to be sure is to measure?
    Drop links are correct, I'm ordering a set tomorrow, if you phone and quote vectra c you get them cheaper apparently..?
    Sent from my iPad using Forum Runner
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Quote Originally Posted by Steven View Post
    Report back tomorrow after you ring them, think i need new drop links
    Regular Member Keif's Avatar
    In the Garage
    The drop links are correct, however I had them on my car and they lasted less than 2 years before I had to replace them.
    I am the only member on here that's had issues as far as i'm aware.
    As for the ARB bushes, the only way to 100% get the correct size is to either get the part number off the ones fitted to your car and check what size they are.
    Or measure the diameter of each ARB (this will need to be quite accurate as they come in 1mm increments)
    Nottingham, emec#7
    Vehicle : Mazda 6
    Year : 2019
    Right i got a confirmation from that the rear arb bush are 19mm.
    Still don't know what the fronts are. Its either 24mm or 25mm. Does it matter too much if its 1mm bigger?
    In the Garage
    Quote Originally Posted by hothatch View Post
    Yes, the bushes hold the ARB tight. 1mm bigger it's won't hold the ARB.
  1. Lowering / bush/links replacement.
    By Lordish in forum Handling & Braking
    Last Post: 12th December 2012, 21:10
  2. Lowering / bush/links replacement.
    Last Post: 6th December 2012, 15:53
  3. drop links?
    By vekky c in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2012, 20:17
  4. Drop Links
    By spennny in forum Engine & Drivetrain
    Last Post: 27th January 2012, 16:49
  5. drop links again.....
    By bobby-tupper in forum Suspension, Wheels & Brakes
    Last Post: 10th June 2009, 09:08
