Thread: sump plug stuck
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    Default sump plug stuck
    right went to do an oil change today and the sump plug has be way over tightened by the garage that did it last time. it has rounded off and mole grips didnt shift it. should i purchase so irwin bolt removers?
    Sep 2009
    Glasgow
    mixed reviews on these removers, I had to whack at mine with a chisel, nothing worked apart from that.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    mine was the same I drilled a small hole through the plug and let it drain the oil out then I ground the head of the sump down with a small angle grinder then used an extractor to remove the shank of the plug
    replaced sump plug with one for a Renault takes a big key to remove it what had been put in was something from a BMW so im told
    none of the local factors round here had one for a vauxhall
    you could always buy one of those vac pumps and not worry about the plug
    http://www.ebay.co.uk/itm/SILVERLINE...item3374375bbd
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I tried irwins,mole grips basically every thing what i ended up doing is got a socket a size smaller and tapped it on with a hammer that got it off.
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    I have a set of irwin bolt removers and they are a brill piece of kit havnt come across a bolt yet that these things cant remove!! as for removing bolts with a chiesel on a alloy sump thats just a bit mad!! one slip and a new sump would be on the cards!!
    lincolnshire
    irwins are good but a good sharp chissel should also do the job as suggested above
    Sep 2011
    lewes
    Engine : 1?? - Teapot mapped
    Mileage : 125000
    Same here, my sump nut was proper rounded and the Irwin socket had it straight off
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Mine was the same. The last oil change I had we had to use a suction pipe to remove the oil. The garage was talking about welding a nut to the sump plug and removing that way.
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    I bought a Seago oil extractor to remove the oil through the dipstick hole--found it to be an excellent tool--just make sure the engine is hot first,pump up and then just keep an eye on it---Dave
    Regular Member Exclusive BV's Avatar
    West Midlands
    can you not just hacksaw a slot into it and get it off with a bit flathead?
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Removing stuck sump plug
    By Big Knox in forum Engine & Drivetrain
    Last Post: 29th February 2012, 18:08
  3. Sump Plug Stuck Fast...
    By spoons in forum Engine & Drivetrain
    Last Post: 16th November 2011, 23:31
  4. Stuck sump plug - oil extractor question
    By cheekylemon in forum Engine & Drivetrain
    Last Post: 2nd January 2009, 00:14
  5. getting the sump plug out ????
    By Nickzx6r in forum Engine & Drivetrain
    Last Post: 6th October 2007, 07:55
corsa d sump plug stuck
vectra c sump plug stuck
vectra c oil sump plug seized
sruck vectra sump plug
remove a tight z19dth sump drain plug
sump plug stuck
vectra c sump plug
insignia sump plug stuck
corsa c sump plug stuck
vectra c sump bung
2.0 cdti stuck sump bolt
