Results 1 to 10 of 23
Thread: Pressure washing engine bay
    New Member NedVincent's Avatar
    Mar 2013
    Mid Norfolk
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 76 000
    Default Pressure washing engine bay
    Morning all.
    This Saturday im cleaning a polishing my car to the max to be able to take some photos.
    I also want to tidy the engine bay up a little and have a pressure washer at my disposal.
    Are there any parts of the engine i really need to be careful with and keep away from? Or can i just go to town and wash away?
    Keep it on a lower pressure maybe?
    All comments welcome
    Dec 2011
    Seaham
    It would be better if you could use a steam cleaner. However, warm the engine up, apply degreaser and then rinse off with a garden sprayer, the hand pump type. You can fill it with hot soapy water and it is easier to direct into the nooks and crannies.
    Or if you have a compressor, try a parrafin gun, again with a hot soapy water mix after the degreaser.
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    With the sheer amount of electrics that a modern engine bay has in it these days, I don't think I'd bother unless it was absolutely necessary following an oil leak etc. In days of yore you used to could just cover the distributer, coil and alternator etc with poly bags and batter in, but I dread to think of the damage you could cause with dampness in amongst all your sensors, fuseboxes, wiring etc these days.
    If you feel it needs a clean, then I think it would be far safer just to clean around as many bits as possible with a clean rag, or a rag soaked in a suitable detergent, then perhaps do the plastic bits with plastic dressing. Just my opinion.
    Mar 2013
    Mid Norfolk
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 76 000
    Righto Ben5on, cheers for the advice. Just thought id be a good boy and clean more than whats just on view to people.
    Ill be carefull and not use the pressure washer.
    Mar 2013
    Mid Norfolk
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 76 000
    Makes sense puppet. Engines these days are totally different and very good point with dampness in the engine bay with all those electrics.
    Wet rag it is.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I wash mine with the pressure washer every month and have no probs at all.
    Dec 2011
    Seaham
    We are not saying dont do it, we are simply saying be careful how much water and what you are pointing it at. You could even try one of those home steam cleaning devices to help move the most stubborn of stains.
    Mar 2013
    Mid Norfolk
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 76 000
    Cheers guys, ill take it easy and watch what i shoot my load over, making sure i miss all 'sensitive' areas.
    Dec 2011
    Seaham
    Lot easier, just not opening the bonnet..... lol
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    Quote Originally Posted by Ben50n View Post
    Agreed lol
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. Noise from engine. May be high oil pressure.
    By Shaben in forum Engine & Drivetrain
    Last Post: 18th May 2012, 19:36
  3. vec 1.8 vvt engine oil pressure
    By sjm1966 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2008, 23:01
  4. Engine oil pressure
    By luckyluke in forum Engine & Drivetrain
    Last Post: 21st June 2008, 11:09
  5. Is pressure washing bad for your car ?
    By Cerealuk in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2007, 09:26
