Results 1 to 3 of 3
Thread: Headlamp holder
    Mar 2013
    Scotland, North East
    Vehicle : Saab 9-3 (Vectra C in disguise)
    Trim : Linear Sport
    Engine : 1.9 TiD 150
    Default Headlamp holder
    So just bought a 54 plate 2.0 DTI estate, few issues....number one to sort was a blown headlamp bulb...and thats where the problems started.
    Pulled the passenger side one and discovered some melting of the bulb holder, no wonder 100W bulb. Replaced it (had to use a little force to break the bulb free of melted plastic), works fine.
    Went to swap the drivers side so the colour temp would be the same and to save likely changing it in a week or so, and discovered it was wedged in (explaining the pee poor headlight on that side) as one side is entirely melted away, both the holder for the bulb and the exterior plastic "sleeve" that holds the bulb holder and metal bracket together.
    I can get an H7 holder with little no issue online, but its the plastic sleeve that is proving to be an issue to find (or I'm just not giving google the right wordings)
    Any idea for a source other than Vaux? (unless Vaux are cheap enough for the part?)
    May 2012
    UK
    I'm pleased I went with the 55w bulbs now!!
    Mar 2013
    Trim : Linear Sport
    Ok so Vaux dealer locally reckons only able to supply a full headlight assembly.
    Turned to Ebay...seller reckons can do fittings and the wires for both sides for £23 inc postage...so meant to be coming next few days
    (Good because the MOT is up in April...)
  1. Headlamp washers
    By redraptor_141 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2010, 18:10
  2. Vectra c/signum cup holder coin holder
    By Robbie69 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 13th December 2008, 19:21
  3. Headlamp protectors
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2006, 22:38
