Thread: vectra cdti camshaft pulley problems
    Nov 2012
    ireland
    Default vectra cdti camshaft pulley problems
    hi guys, i seem to have a problem with my camshaft pulley, the keyway is casted onto the pulley, theres a slot cut into the cam shaft, but when refitting the pulley the keyway isnt tight in the cam? theres a full tooth of play in the pulley? anyone no which was to tighten it or what the procedure?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    What have you done to get into having the camshaft sprocket off in the first place ?
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    I had mine off the other week changing the water pump, mine was a snug fit with no play at all. Does it look damaged in any way? Have you got it the right way up?
    Nov 2012
    ireland
    is yours a 120 or a 150? mine is a 150 dont think the pulley has to come off to change pump so u must have a 120? not damaged in anyway even have a new one its the exact same,
    since ive had car ive had camshaft sensor out of range fault showing, have changed cam sensor, crank sensor, checked all wiring, ecu etc, so the last thing to check was the pulley itself,
    thinking i will need timing tools now to get it right.
    May 2011
    South London
    Set the timing up and align the camshaft sprocket with the bolt loose follow the instructions as below
    lock the camshaft with a camshaft locking tool (not the one below) and tighten the camshaft bolt to correct torque.
    From the link at the bottom of this post Sealey Tools
    Z19DTH (DOHC) - Fit VS4776 Camshaft Setting Tools
    Camshafts have a 'timing position slot' and are locked in
    timed position by VS4776 Setting Tool, which is spring
    loaded, screws in to the camshaft housing and locates
    into the timing slot.
    Slowly turn the engine in its normal direction of rotation.
    As the ends of the spindles engage the slot in the
    camshafts an audible 'click' will be heard as the springs
    push the spindles into the 'timing slots'.
    IMPORTANT: DO NOT use Timing Tools to hold crankshaft/camshafts in position whilst releasing or tightening the sprocket bolt.
    Setting
    Tools are for retention of timing position only
    http://www.tooled-up.com/artwork/ProdPDF/VS4775.pdf
    Nov 2012
    ireland
    cheers dude i was thinking as much ! someone must have the pulley off before thats why its never been right!
    Nov 2012
    ireland
    Just to clarify if I use the tools an loosen camshaft pulley an follow the instructions the pulley will sit in the correct position for torque ?
    May 2011
    South London
    This might help what Im trying to explain
    So basically the cam bolt is the last thing to tighten on the re-fitting of the belt.
    DaNm convert to Nm move the decimal point to the right eg: 2.7 DaNm = 27Nm
    Nov 2012
    ireland
    Ace, just ordered timing tools cheers dude !
  1. camshaft pulley removal
    By Harlboy in forum Engine & Drivetrain
    Last Post: 26th December 2012, 18:17
  2. camshaft sensor reading problems with cdti 150
    By alan opel in forum Engine & Drivetrain
    Last Post: 23rd December 2012, 13:03
  3. vectra cdti problem camshaft sensor
    By alan opel in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2012, 20:23
  4. cold start problems due to camshaft sensor fault ?
    By jaykay in forum Engine & Drivetrain
    Last Post: 15th June 2012, 19:05
  5. vectra v6 cdti tensioner pulley
    By Critch in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 21:51
vectra cdti crank pulley removal
1.9 cdti camshaft sprocket removal
how to lock cam pulley on vectra cdti 1.9
https:www.vectra-c.comforumshowthread.php182901-vectra-cdti-camshaft-pulley-problems
vauxhall zafira 1.9 tdi brken camshaft sprocket
vectra c 1.9 cdti camshaft pulley
vectra c cdti cam shaft pulley
vectra c camshaft alignment tool
is the 1.9 cdti cam sprocket keyed to shaft
vectra cdti bottom pulley play
vauxhall vectra 2008 1.9 cdti camshaft pulley bolt
vectra 1.9 cdti cam sensor location
z19dth cam pulley broken
z19dth camshaft sensor test
vectra cam pulley out of line with sensir
vectra c camshaft sprocket
insignia crank pulley failure
what is tighting torque for camshaft box on 2014 2.0 vauxhall insignia
how to remove camshaft bolt vectra
is there a cam shaft lock lug on a 120 cdti
2.0 cdti removing crank sprocmet
2010 zafira 1.9 cdti crankshaft locking tool location
fitting camshaft senser vauxhall 1.9
1.9 cdti cam locking tool
removing camshaft pulley on a vectra c 1.9cdti
