Results 1 to 10 of 11
Thread: Vectra C Brake Pad warning light help
    Jan 2012
    Telford
    Default Vectra C Brake Pad warning light help
    Hiya guys, Since I have owned my 2.2 Direct the pad wear sensor has been on, inspected all pads and they are nearly new, I am trying to locate a sensor wear cable and cannot find one (Hence why the light is on) Can anybody shed any light as to where the connector might be? Cheers
    newport
    should be on the passenger front wheel, maybe they have unplugged it, mine was damaged so for now i have just bridged the 2 wires to turn it off
    13 Post(s)
    Are you sure it's the brake pad wear light? At some point the warning light was dropped on the Vectra-C.
    My 2006 2.2 Direct Vec-C elite doesn't have it, but can't remember when the feature was dropped.
    Jan 2012
    Telford
    For some weird reason there is no cable there, im wanting to order a new one but not sure where the connector is to plug it into the car lol!
    Its deffo the brake pad sensor light:
    Cheers for your info guys.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    There should be a plug with nothing in it if its been removed. you can simply shove a wire in the two terminals to link it out. This will put the light out. Or just buy a new sensor.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    On my car the front nearside has the pad sensor, just to the right off the strut there is two cables fixed to the arch inner, the left one is the pad warning cable (from here is where yours must be missing) and the right one is for ABS.
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    It's wired to the left front pad.
    However, the warning light can appear for three reasons :
    - If the pad is worn (please keep in mind the inner pads wear much faster than the outer ones, and since checking them is far less easy, a lot of people, including myself and most garages, just check the most accessible one and think it's OK while it's not. I had my rear inner pads metal plate scraping the discs, while the outer ones were still OK) ;
    - The sensor cable is unplugged or cut ;
    - Your brake fluid level is low. It's the same warning light ! You should check your brake fluid tank and if the level is under the minimum mark, check for leaks somewhere.
    I had a leak at the ABS block after the garage messed up with a replacement pipe (they destroyed the original one's threading while trying to unscrew one of the hoses), so it had to be remade (the hard pipes aren't sold as parts, they're made out of straight pipe sold by the length, even from GM, and shaped on purpose).
    If your brakes pipes have never been touched, maybe one of your hoses has been rubbed by a wheel and has been pierced ?
    Jan 2012
    Telford
    Thanks for all your help guys, there is plenty of fluid there as there is no cable there im pretty much certain that the cable is the problem I just need to try and locate the socket to plug a new one into, ill have a look around areas given it must be there somewhere. Thanks guys
    13 Post(s)
    Quote Originally Posted by Z80 View Post
    Low brake fluid light is the same one as the handbrake light, not the low brake pad warning symbol.
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Just had a look at mine yesterday--done a brake service and i have no brake pad sensors fitted! either side!! not too worried as its less to worry about.I run a 58 Sri veccy-1.8vvt--one of the last one's to be made i think----Dave
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. My brake warning light is on
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 22:07
  3. third brake light warning
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 21:13
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake Pad Warning Light
    By nufckev in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 13:35
brake pad warning on vauxhal vectra
vectra brake warning light
Does 2006 vectra c 2.2 direct have brake pad wear sensors
vectra c brake pad wear sendor light
vectra c pad wear sensor
