hey guys new to the site just wondering if the Vectra vxr front breaks would fit on my facelift 1.9cdti Vectra or shud I just stick with buying a set of signum /Vectra v6 cdti breaks help would be much appreciated cheers![]()
The VXR 345mm brakes will fit fine (and I believe even fit under the 17" wheels). Although I would look at upgrading the rears to the 292mm at the same time for balance if you don't already have them. Most people however choose to upgrade to the 314mm V6 setup as they are a substantial improvement in braking at a much cheaper price than the VXRs.
Either way you need to change the calipers, carriers, disks and pads. They're not interchangeable.
Maptun Tuned 2.0T Estate - click HERE for mods list.Brentwood 2012: Winner, Saturday Show. Hull 2012: Winner, Best Estate. Hull 2013: Winner, Best Estate & Runner Up, Best I.C.E
will my standard rear brakes be ok with the v6 ones as ive just baught a set lol
they will be fine
cheers for the help guys im hopefully going to get fitted this weekend lol
i know you said youve just got the brakes but for others wanting to go down the route of 314mm front brakes
disk/pad kit 93186299
314mm caliper seal kit 93185768 x2 (if your fussy and dont trust the age/condition of the calipers)
stone guards LH 13203489 RH 13203490
then some fresh brake fluid to again if your fussy and want to do a fluid change at the same time
Or just cut the shields
what shields?
The stone guards/heat shields at the back of the disc on the facelift cars with 285 brakes cover the whole of the back of the disc with only a cut out for the small caliper. You have to cut a triangle out of the top and bottom of the shield to fit the 314 caliper![]()
At last !!!! There was something actually added to the face lift!!!!
