Results 1 to 3 of 3
Thread: DRL question
    Regular Member Carl83's Avatar
    May 2011
    Basingstoke, Hampshire
    Default DRL question
    Hi,
    Im not really a fan of the aftermarket DRLs, but Im possibly thinking about getting some.
    I don't want to spend a fortune on them and have found these two...
    Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item...d=370729813072
    Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item...d=400306524995
    Is it as simple as wiring them straight to the battery? Is there anything else involved, such as relays or switches? I guess I would want them to come on as soon as I turned the car on.
    Also, would I need to take the bumper off or could it be done without doing it?
    Carl
    Sent from my Samsung Galaxy SII using Forum Runner
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Fuse F10 under the bonnet is ignition controlled, use it if you don't have afls. A relay to knock them off with the sides isn't a bad thing. I didn't take my bumper off, i removed the undertray and went from there. Mine.
    hull
    Don't bother with either of those mate, very poor quality and lasted only a couple of days on mine before water ingress killed them, seller refunded though.
    These are better from this seller, E marked on the glass so legal and much better built, i had these first which lasted about 11mnths.
    http://www.ebay.co.uk/itm/1209833804...84.m1423.l2649
    Iknow they look identical but are better built, glass lens, thicker cable, and watertight E4 proven, only problem is the wait to get em from china was about 20 days.
  1. question for ya !!!!!!!!!!
    By melvyn8181 in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2012, 23:12
  2. HID Question?
    By OPC in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2011, 22:03
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. 1.8 SRi vvt question
    By Rh08 in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 20:18
