Thread: EGT engine management light
    Apr 2012
    wigan
    Default EGT engine management light
    Had the issue of the engine management light on since Nov now. The code is reading as the exhaust gas temp sensor (high circuit) The car is running really smooth and fine. Also getting about 29-30 mpg on short trip to work. Vx have tried to clear the code but it just comes back. As the car seems fine can the code be wiped out in any way?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you actually tested voltage?
    if ecu sets a high voltage code it means its looking for the voltage to be pulled down by the sensor and its not being pulled down so their for sets high voltage code.
    Apr 2012
    wigan
    no not tested anything, but I can test the voltage, what would be a high voltage? and can it be sorted without replacing the sensor as they are over £100
    Apr 2012
    wigan
    could it be blanked or earthed out?
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    I'm not sure if they run on 5v reference or 12v
    either way its likely to show that its stuck high.
    can test with test light pulling to earth.
    if all is ok then unfortunately the sensor will be at fault
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
