Results 1 to 10 of 13
Thread: Oil leaking fast 3.2 V6 Vectra C
    Hereford
    Vehicle : Vectra C 3.2 V6
    Engine : Z32SE
    Mileage : 120k
    Eek Oil leaking fast 3.2 V6 Vectra C
    Hello,
    my 05 Veccy has developed an alarming oil leak. When the engine is running it drips out at +2 drips /sec.
    It's coming from the front near where the engine and gearbox join, just on the engine side. It's directly in line with the nearside front engine mount and about 2 inches above it.
    I can see it dripping, but can't see exactly where it is sourced. It doesn't seem to be the sensor that is in the block there.
    Any ideas what to do next or what it is most likely to be ?
    Any pointers much appreciated.
    I expect, "take it to the scrappy" may be the best answer.
    Reg
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    If it looks like its coming from the sensor it might just be a seal.
    Hereford
    Engine : Z32SE
    Mileage : 120k
    Seems to be from above the sensor, nearer the gearbox end. I'll have to take it apart and have a better look. There are 2 metal pipes running in front of the leak. I suppose it could be the back of one of those.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    33 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Might be the oil heat exchanger or the seals on the pipes feeding into or out of it. Paul
    Hereford
    Engine : Z32SE
    Mileage : 120k
    Hi Paul,
    thanks for reply. Is that oil heat exchanger on the upper end of those 2 metal pipes ? The lower joints are clean n dry.
    Reg
    Hereford
    Engine : Z32SE
    Mileage : 120k
    http://www.lmfvauxhall.co.uk/image.php?type=D&id=2046
    I found a picture of an oil cooler for the Z32SE, where does it live on the engine please ?
    Reg
    Glasgow
    It lives in the middle of the V, its a fairly big job to change and its a common failure on the 3.2's im afraid. It fails due to corrosion.
    Hereford
    Engine : Z32SE
    Mileage : 120k
    Thanks for that. I will take the lid off tomorrow. Is it in the variable venturi plenum bit ?
    Glasgow
    Quote Originally Posted by Big Reg View Post
    Its underneath it, i remember when it was in the dealers getting done i was shocked at how much that was stripped down to access/remove it.
    Hereford
    Engine : Z32SE
    Mileage : 120k
    Nothing is ever easy. Of course my Haynes manual doesn't cover the engine I have. Grrr .
    Thanks again for the info.
    Reg
  1. my vectra Sxi is leaking!!!!!!
    By ade hammond in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 10:09
  2. So you think a Vectra VXR is fast....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 23:44
  3. I thought VXR Vectra were fast? :)
    By _ZS_ in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2008, 15:16
  4. Can I get my Vectra to go this fast?
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 19:54
v6 vectra oil leaks
what is the sensor abovei the sump sesor on vectra sri v6
vauxhall vectra 3.2 sump sensor oil leak
can you make vectra c gsi faster
vectra c 3.2 oil leak
oil cooler ‎leakage vectra c 3.2 forum
