Thread: Crank seal replacement on Z20NET, cost?
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default Crank seal replacement on Z20NET, cost?
    As above, I have an oil leak and it has been suggested that it could be the crank seal, any idea how much this would cost? I'm fairly handy with tools, would this job be accomplishable by a DIY mechanic? Are there any other parts I'd need apart from the seal itself?
    Jan 2012
    Dublin
    Depends which seal, is it the front seal by the belt or the rear seal by the box? front seal isnt the end of the world, just pop the belt off and pick the old seal out, press a new one in. Rear seal is a gearbox, clutch and flywheel out job, not cheap.
    Edit: and yes front seal is easily done by a home mechanic as long as youre comfortable with re-timing and installing the belt
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Except its a chain not belt...
    Jan 2012
    Dublin
    ah nuts, haha i read it as z20let, the net engine isnt much different to do a front seal on except you'll be spared the arse ache of having to time the engine. Pop the harmonic balancer off the front of the crank. Lever the seal out of the timing chain cover, press the new seal in flush with the cover and bobs your uncle, lube the lip of the seal with oil and put the balancer back on, torque her up and refit the aux belt. Job done
    oh well.. I tried..
    LOL.. what i get when i mention a Z20NET.. 'A what? wtf is that mate? never heard of that'
    Engine : Z20NET
    Quote Originally Posted by IrishVectra View Post
    Thanks for that, doesn't sound too difficult, it's the front seal I think, I first noticed oil on the bottom and side of the sump when I last did an oil change, then looking down that side from above below the aux belt I can see oil.
    I had provisionally booked it in for this and a pre-mot next monday but I may give it a go myself in the meantime as I'll be working on the car most nights this week, got new shocks and springs to fit on the front, a powdercoated cam cover, also got rear electric windows to do and a few other fiddly bits.
  1. 2.0T oil leak, poss crank seal or sump seal?
    By mann3210 in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 11:11
  2. crank seal
    By boz1300 in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 21:03
  3. front crank case oil seal
    By b3kaw in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 22:50
  4. Crank Shaft Oil Seal !!!! PLEASE HELP!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:53
  5. Crank Oil seal on a 1.9cdti 16v
    By robblue2x in forum General Chat
    Last Post: 13th March 2009, 08:14
corsa c crankshaft oil seal replacement how much
05 zafira 2.0 dti installing rear crank seal
crankshaft seal opel zafira price
vauxhall 1.9 cdti cranhseal replacement
front crankshaft seal replacement cost
crankshaft seal leak cost
How many oil seals is there on 2.0dti cranksaft
crankshaft seal replacement vauxhall
zc vectra front crank seal
08 opel vectra 1.9 diesel crank seal leak repair cost
vectra c 2.0dti crank seal
vectra 2.0 dti crank seal replacement
z20net crankshaft seal replacement
crank seal price for signum car
crankshaft seal vectra c 1.9cdti
2008 vauxhall zafira crank seal replacement
corsa c crankshaft oil seal rear vs front
crank seal corsa cost
crankshaft oil seal corsa replacement price
crank seal replacement cost
https:www.vectra-c.comforumshowthread.php182838-Crank-seal-replacement-on-Z20NET-cost
