Thread: powersteering help
    Jan 2010
    Dewsbury
    Trim : sri
    Engine : z28net
    Default powersteering help
    hi all just had pump and rack changed and still no power-steering what could be causing this please?
    im lost no one can seem to find fault
    Dec 2011
    Seaham
    The pump is electrical, is there a positive supply going to it? I am sure someone on here found that the large connector next to the battery was missing a bolt/nut and hence the power was intermittent?
    Jan 2010
    Dewsbury
    Trim : sri
    Engine : z28net
    its on vxr and been told it mechanical constant belt driven does not use newer electric unit
    Dec 2011
    Seaham
    If its a belt driven system, then is the pump actually working and pumping fluid to the rack. Have they connected up the flow and return pipes the right way?? Has the sytem been bled? I understand they are self bleeding, however you need to move the steering backwards and forwards with the engine running.
    Jan 2010
    Dewsbury
    Trim : sri
    Engine : z28net
    as far as im aware they have had car running to bleed system and they are checking pipes again now but say they defo did then right way
    Dec 2011
    Seaham
    Well there is definately something at fault? it is a straight forward system, it is possible to have a faulty new steering rack, although I would say that it is the pump side.
  1. Powersteering fluid on 3.2
    By jamesr in forum Engine & Drivetrain
    Last Post: 11th February 2011, 18:35
  2. powersteering help
    By sean-s in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2011, 17:11
  3. Powersteering has stopped??
    By kiwiboy in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2009, 21:27
  4. Powersteering keeps stopping
    Last Post: 9th August 2009, 00:11
  5. powersteering
    By steeb82 in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2008, 13:38
