Thread: aftermarket cam belt kits and water pumps
    Nov 2011
    devon
    Vehicle : vectra 1.9 cdti
    Trim : sri
    Engine : 120 8v
    Mileage : 84000
    Default aftermarket cam belt kits and water pumps
    does anybody use aftermarket on either as a mate recommended using gates belt kits and i have found water pumps are a lot cheaper as well.since oe is made by someone else does anyone know the brand?
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Gates are good.. Dayco are worth a look too for timing belts
    As far as water pump.. Firstline or FAI
    Jan 2012
    Dublin
    gates, FAI or conti belts are all reliable and OE quality, with water pumps i tend so steer clear of after market stuff unless its an OE manufacturer, last thing you want is the seals in a cheap pump leaking through the impeller shaft, or the bearings seizing and throwing the timing belt off screwing the engine
    Jun 2011
    brum
    I'd just get yourself a tradeclub card (if you haven't already) and get a genuine one. they come in at around £75 for the full kit with the trade club discount. The gates kit's aren't that much cheaper than the genuine ones at RRP from what i can see, so i'm assuming your asking for quality purposes rather than saving a few quid.
  1. SRi and aftermarket lowering kits
    By The Flying Banana in forum Suspension, Wheels & Brakes
    Last Post: 6th July 2011, 05:36
  2. water pumps
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 22:43
  3. Aftermarket HID Kits...Any good?
    By Ademusic in forum Introduce yourself.
    Last Post: 27th December 2009, 10:59
  4. Vauxhall has no water pumps
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2008, 19:20
  5. Aftermarket HID kits and the Law
    By lee_eardley in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2007, 02:42
