Will car breathe better (cold air)if plastic cover which is blocking air intake when bonnet is closed is removed ?
anybody ??
Come on, give us more than 2 hours to respond, some people on visit once every few days...
If you want to compare, simply unclip the grille and remove
Personally, it won't make difference as the air volume will be the same
Equally a higher speeds the air will be slightly more turbulent (as the fascia removes this) and so may make it worse...
If you want to improve the air intake then add an additional channel so that it is fed from both sides of the grille (although you will need to modify the grille)
