Thread: Airbag Squib HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
    Jan 2013
    warrington
    Default Airbag Squib HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
    Howdy Folks, hope you can help, ive had airbag light on my vectra c pre facelift forever, i had a mate read the codes today and this it what came up, has anyone any advice as to what they mean and were I should start looking???? Thanks in advance steve
    Total number of fault codes: 2
    B0012 - Driver Airbag Squib Circuit (Stage1) High Resistance
    (0D) - Present
    B0013 - Driver Airbag Squib Circuit (Stage 2) High Resistance
    (0D) - Present
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    could be wrong but think the squib is part of the CIM , if this is the case then you should be able to get a CIM from the scrappers , then put the innards in it from your CIM so that it doesn't need to be programmed in.
    Administrator plasma's Avatar
    On the Forum
    497 Post(s)
    Engine : 150
    Mileage : 74000
    as above, could be a cheap fix, easy enough if you know your way around spanners/screwdrivers
    Jan 2013
    warrington
    Hi could you explain what the CIM is and where to find it thanks steve
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The airbag squib is the pyrotechnic charge that is detonated causing near instantaneous inflation of the airbag under certain conditions.
    Typically, high resistance would mean it is connected but the connection is bad, loose or in some way damaged.
    It may well be a simple case of the plug having come loose from the back of the airbag unit - an old known fault as the plug was an utter pig to seat fully. It may also be some other damage.
    If you're going to deal with it yourself, follow the system discharge procedure... ignition off, keys out..... wait 5 minutes.... disconnect battery negative and secure it well clar of possible reconnection.... wait five minutes... now the system should be discharged and safe to disconnect/reconnect components.
    Being a safety system, you will need to have the fault light extinguished by a Computer Based Application - it does NOT reset on it's own once any fault is cleared.
    Regular Member michale_kid's Avatar
    Feb 2015
    Oooold post but after reading this could I have damaged something when replacing the speaker in my cim module?? As I am getting the same codes after changing the speaker...
    And when just swapping out the insides of one cim to another.. what parts would I have to keep from mine to make sure it still works??
    Sent from my ONEPLUS A5000 using Tapatalk
    On the Forum
    497 Post(s)
    Engine : 150
    Mileage : 74000
    quite possibly if you moved the squib as its a wound ribbon cable and can only move 2 turns in each direction
  1. Air bag squib repair
    By simon7257 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2016, 00:19
  2. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  3. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  4. airbag
    By samuel hosick in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 20:10
  5. Airbag help
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2008, 15:02
vectra c squib does it need tech 2
vectra squid air bag
airbag squib for vectra c
Vauxhall insignia airbag ribbon
