Thread: Any Plumbers?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Question Any Plumbers?
    My central heating system has 8mm Microbore piping. I want to change the pipe that comes through the flooring in the hallway as who ever fitted it made a pigs ear of the way it comes through the floor(all bent and not straight) and my OCD can no longer cope. I am about to replace the laminate flooring this week so it makes sense(to me anyway) to do something about the pipe work. So when I have the flooring up I want to cut back the 8mm pipe work, fit an 8mm to 15mm joint, then 15mm pipe up to new TRV's. Thing is the 8 to 15mm joint I have wont accept 15mm piping, the 15mm side is the same size as the 15mm copper pipe. Now looking at the screwfix catalouge you get Couplers or Reducers, so which will the 15mm pipe fit into, Couplers or reducers?
    Hope you understand what I mean.
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Astra Sports Tourer
    Trim : active
    Engine : 1.7cdti
    If i understand you right you need to get a 15mm x 8mm reducer which should then fit in a 15mm coupler which the 15mm pipe fits into
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Fyi the 'pushfit' plumbing kit is very good. No faffing about with soldering etc. Fast and safe.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by Daywalker View Post
    Ah, yes, got you.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by nikroc View Post
    I used them to plumb the washing machine, not sure about under the floor on a central heating system where i cant get back to them though and screwfix dont seem to do them in 8mm.
    peterborough
    if it's what I think it is you would need a 15mm straight soldered connection in each one too. the 15mm end you have on the reducer is made to go into a 15mm rad valve
    would probably be easier to just buy a few of these
    http://www.ebay.co.uk/itm/15mm-x-8mm...item2306973eb4
    im not a fan of pushfit, had a few blow off after installers not fitting properly
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by Kevinw29 View Post
    Cheers, just found them on screwfix, was thinking they might be easier, or rather less soldering.
    peterborough
    definatelly a good thing when they are gonna be hidden under floor.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Cheers guys, I think I will get both the compression and the solder joints.
  1. Any plumbers in here
    By dannyjpuk in forum General Chat
    Last Post: 26th January 2012, 09:17
  2. Any plumbers on here?
    By lee gsi in forum The 'Off Topic' room
    Last Post: 30th December 2011, 23:18
  3. Plumbers
    By Daywalker in forum General Chat
    Last Post: 21st October 2010, 18:02
  4. any plumbers on here
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 30th September 2009, 22:07
  5. Any Plumbers on here ?
    By markm in forum The 'Off Topic' room
    Last Post: 6th March 2008, 23:27
