Results 1 to 10 of 11
Thread: Halfords HB010 battery in Vectra C a bit smaller than stock, can't fix it down
    Aug 2009
    Wales
    Default Halfords HB010 battery in Vectra C a bit smaller than stock, can't fix it down
    The battery in my Vectra just failed. Not bad going, since it was the factory fit one and the car's from 2003!
    Halfords recommended their hb010 battery which I've fitted, but I noticed that it's a bit smaller than the stock battery.
    Also, I couldn't get the battery retainer clip to tighten; it felt like the thread had been rounded but I don't see how that could have happened. Is there a trick to getting them to tighten up? I don't want this smaller battery moving around and damaging the terminals.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Most replacement ones for cdti's i found were smaller & were not as good!, The cold starting/cranking was slower & the actual size & weight was far less, When my old corsa 1.7d battery failed i put the smaller aftermarket vec'y battery on that & went back to the same supplier & got the next size up (IE for transit's & similar but it was identical in size & weight to the factory one, this gave better cranking speed hot & cold), Before anyone says it was wrongly supplied first time 'not so' as the motor factor is a friend & the catalouge numbers were correct.
    13 Post(s)
    Quote Originally Posted by asktoby View Post
    I don't want this smaller battery moving around.
    It will also fail an MOT.
    I've just had to have a new battery and likewise it's a bit smaller than the original one. Vauxhall garage fitted it though, so no idea about the fixing points.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I'd take it back and ask for a bigger battery
    Aug 2009
    Wales
    I managed to get the gripper to hold the battery down but, because it's shorter, it could still move forwards and backwards. I've fixed that by wedging a block of wood between the battery and battery housing wall.
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Hello, i think that halfrauds have just given you anything that looks like the right battery,i would be taking it back and speaking to the manager,you should not have to be putting bits of wood in to hold it down,i bought my new battery from euro car parts [a bosch one] and fitted it in no time at all.As i say take it back and have a word with the manager--not good service at all-----Dave
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Just looked at that battery number-hb010--dear me that is expensive!!!!you can buy 2 bosch batterys for that and still have money left for a pint!!I try not to use halfrauds if i can--rather buy online and have it delivered-----Dave
    Aug 2009
    Wales
    Just to follow up: The car went through MOT fine with the battery wedged by wood.
    I paid trade price for the Halfords battery so it was significantly cheaper than the Bosch.
    Car is running fine.
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    You are probably missing the small plastic piece that prevents the battery moving forward from your battery box (as I was). It's a tiny little chock, about 2 inches long by 1 inch wide that just clips into the battery box. You'll probably be able to get one from a scrappy from a 1.8 petrol vec or similar. I got mine from a signum.
    Cost - £1 English pound! Vx wanted £15+ for it.
    Also, this won't help you now but if anyone else is checking, try and find a local branch of Andrew Page, as this is where Halfords and ECP order their Bosch batteries from. I got a full size Bosch S5 Silver battery (same size as OE VX) for £78 including VAT. Halfords wanted £130 for the same one, or £95ish on trade, and ECP were quoting £95ish as well so it still represents a massive saving over the big name places.
    West
    As already said take the battery back, i would rather have a Bosch s5 which i baught for my last vectra or a Yuasa which i baught for the shogun... both great batteries & will cost no more than a Halfrauds own brand
  1. Is the signum fuel tank smaller than vectra?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 02:27
  2. Which smaller car (172 or St170)
    By Gregg in forum The 'Off Topic' room
    Last Post: 15th April 2010, 19:02
  3. Black Vectra Huntingdon Halfords
    By parsco in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 10th August 2009, 13:29
  4. Smaller tyres
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 26th March 2009, 17:52
  5. Vectra C original stock audio
    By veiluoks in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 12:43
vectra c battery too small
HB010 car battery price
halfords batteries
plastic clip on hb010 battery
yuasa 010 insignia
vectra smaller battery
Best price for hb010 battery
Halfords battery bosch vectra 1.9 cdti
batteey 2003 corsa 1.7d halfords
