Thread: parrot muting.....please help
    Regular Member abz007's Avatar
    wolverhampton
    Default parrot muting.....please help
    ive just installed a parrot ck3100 to a panasonic cqc8300n h/u on a vectra c facelift. everything works fine but if i connect the mute wire from the h/u to the parrot kit it works fine at a low volume but as soon as i increase the volume over halfway the parrot keeps trying to mute the h/u. it sounds like the cd is skippin for a split second continuously and every time it skips the words "muting" flashes on the display that split second. Any one who is an expert in parrot kit or has an inkling of what is causing please please please help. i was very proud of fitting this by myself but now this little problem has p**sed on my bonfire.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    What are you increasing in volume? The stereo volume whilst a call is NOT in progress I gather from your description.
    Sounds to me it could be a simple wiring fault. Are you using the ISO interface lead which came with the Parrot kit? Have you tried disconnecting the yellow wire used to mute the radio?
    wolverhampton
    Quote Originally Posted by Ben H View Post
    when i'm not on a call and i put the volume up on the stereo thats when the clipping occurs. if i disconnect the yellow mute wire from the stereo then there is no clipping and its fine but when i get a call the sub woofer continues to play.i am using iso interface leads. everything is working when the mute wire is not connected but i want the subwoofer to cut out when i gat a call and the only way you can do that is by connecting the yellow mute to the stereo mute. hope this make sense.
    Essex
    I had the same problem recently.
    What I had to do was cut the mute wire on the section of loom that came with the parrot kit (the bit between the h/u's connector and the cars.
    This means the mute goes into the parrot mute wire (yellow one in my case) but not into the cars loom.
    So if you connected yours to the 'mute in 1' there will be another wire coming out of that ISO block and into the cars ISO block, cut this wire.
    The problem is the cars loom keeps grounding and so muting the stereo.
    Hope this makes sense.
    wolverhampton
    ok now im confused.....i have connected the yellow wire from the parrot directly to the orange wire of my head unit ( orange mute wire is not connected through the iso loom, it's separet to the iso loom) ...what now?
    Essex
    Quote Originally Posted by abz007 View Post
    Ah ok, mine was going through the ISO connector.
    If it is the same as mine there will be 3 wires with bullet connectors coming from the h/u side of the parrot wiring that are labelled 'mute 1' , 'mute 2' and 'mute 3'. If there is a wire from the h/u going into any of the points on the plug for these then that could be causing a problem.
    worth tracing the wires path to the original vaux ISO plug and seeing if they lead to the cars mute lead. which i think is brown. Cutting this wire might solve the problem but as you said, yours seems to be wired differently to mine so might not be the right wires to cut.
    Sorry I couldnt be more help, but you described the exact problem I had with my car.
    wolverhampton
    you might be right. im gonna have to take it all out 2moro and try what you said. thanks for you help though!
  1. Parrot Mki9200 in CDC40 - Muting problems
    By wellsi in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2011, 14:54
  2. Got the parrot kit but...
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2010, 18:16
  3. can anyone fit a parrot?
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2010, 15:49
  4. Muting a CD70 Navi unit ???
    By tone in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2007, 18:32
  5. muting the stereo
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2006, 21:34
parrot keeps muting carradio
vectra c iso connector for parrot ck3100
How do i mute centre speaker in my 2008 vauxhall
mute wire on a vectra c radio
