Results 1 to 10 of 16
Thread: 1.9CDTi (8v) Timing belt tension
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Default 1.9CDTi (8v) Timing belt tension
    I changed my timing belt a week or so ago but ever since I did it the belt whines. To be honest it did whine before I changed it but both pulleys and the tensioner were changed.
    I wasnt entirely sure how to set the tension but some googling revealed I had to set the pointer so it pointed at the hole in the backplate. I found the pointer and what I thought was the hole so I slackened off the bolt that holds the tensioner in place and levered it until the pointer was as close as I could get it to the hole then tightened up the bolt again. Pressing on the timing belt between the top two pulleys makes the pointer spring up and down and it does indeed settle near the hole but not directly on it, have I done this right? This belt really does whine! Im thinking of taking it apart and slackening it off a bit or is this a bad idea?
    Carnoustie
    Another whine issue lol! Maybe it's not on the toothed belt path? Could be aux belt pulley
    Ronnie
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Mileage : 100k
    It is on there nice and straight. Funnily enough my next job is the aux belt as I noticed it was cracked when doing the timing belt, ive got a new one just waiting for me to fit it. I take it its ok to run the engine with the aux belt removed just to see if the whine goes away?
    Carnoustie
    Quote Originally Posted by Casey View Post
    yes it is ok, just make sure you remove it completely so it does not get caught anywhere
    Does it whine from stone cold or only as it warms up?
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Mileage : 100k
    Its a permanent whine that alters with rpm it dosent change with temp.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Water pump ?
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Mileage : 100k
    Yes I put a new water pump in it too.
    May 2011
    South London
    Do the "remove aux belt" test to see if its quiet, its sometimes the alternator bearing that gets noisy on the 120's
    But check all the ancilliaries on the aux belt run for wear on the pulleys or play in bearings etc.
    Regular Member gixerjd's Avatar
    Dec 2011
    leeds
    Vehicle : vectra c
    Trim : vxr
    Engine : z28neh
    Mileage : 31000
    Quote Originally Posted by C-Owner View Post
    or get some water in a squirty bottle and spray the aux belt if the noise goes away you will know what it is
  1. Replace toothed belt and tension roller guide.
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2013, 12:58
  2. 72k on 1.9cdti 150...should I get timing belt done?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 15:14
  3. 1.9CDTi Broken Timing Belt at 69k Miles!!!
    By Vectra-sceptic in forum Engine & Drivetrain
    Last Post: 24th September 2010, 15:16
  4. Timing Belt Tension 1.9 120bhp TDI
    By jimboy26 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 18:59
  5. 1.9cdti (150) timing belt change £210 is this ok?
    By kirkyoke in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 22:36
vectra c 1.9 cdti 8v timing belt replacement guide
vectra c how to tension timing belt
