Results 1 to 3 of 3
Thread: Front Fogs Cable broken
    Regular Member purple170503's Avatar
    kent
    Vehicle : Vauxhall Vectra C - Facelift
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    Default Front Fogs Cable broken
    I've had on and off problems with the f/n/s fog light on my Vec 'c' for a while due to condensation build up causing issues with the lens.
    Yesterday I had the bulb warning light come on and so spen some time today trying to fix it. It wasn't the bulb but a problem with the white wire than runs to the bulb from up and behind the housing. The connector looks like it has corroded and broken off (so guessing that's my answer) but I can't seem to see inside enough to be able to replace the connector. Has anyone else had this problem with some advice on best how to fix it? Thanks
    kent
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    Managed to get the light unit out, looks like connector broken off inside and having job get it out. Might need to get a new one. Can anyone suggest good place to source one.
    Dec 2011
    Seaham
    Scrap yards? Also get a new wire, unless you are good with a soldering gun and make up the cable yourself. When you say having a job get it out, is it rattling insode the unit or still pluuged in? Pair of good nbeedle nose pliers can normally help pull out broken connectors.
  1. Rear Interior Light Cable Broken
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2009, 18:11
  2. front fogs
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 09:55
  3. 02 - 05 front fogs
    By gsxrster in forum Parts for sale
    Last Post: 16th October 2007, 20:09
  4. Front fogs
    By fishphone in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2007, 12:56
