Results 1 to 3 of 3
Thread: Will they fit ?
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Default Will they fit ?
    Just had car up in the air to investigate a wheel bearing / cv noise I've discovered play in one of the inner track rods and also one of the springs is on its way out so going to change then to see if it cures the knock now the question is I've got a set of front struts that we took of a 2.8 t siggy we have broke would it be ok to fit these to my 2.0t or are the 2.8 ones different
    South east
    They should be fine as long as you change the springs, because the 2.8's springs will be for a heavier car than yours.
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    its the springs i was asking about as one of mine has stated to break (its bending out of shape) i thought it would be a differnt strength from the 2.8 guess ill have to invest in a new pair does anyone know best cheapest replacement ones to fit
