Thread: Flooded carpets then 7 setting blower fail
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default Flooded carpets then 7 setting blower fail
    Had the problem with flooded carpets due to scuttle hole being blocked. Sorted blockage and was trying to dry off carpets but blower has failed on all settings.
    Looking through the how-to’s there is lots on the 4 blower setup (resistor pack) but looks like the 7 speed setting is a bit more complicated (does not have a resistor pack??).
    Is there a definitive how to for fault finding a 7 blower setting problem?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Then its the climate control you have... and thats have a resistor pack... just very much more expencive.. (and no easy fix)
    Jul 2006
    greenock
    hi ken P, cant find the resistor pack - any ideas where it is. Looked through the 56 page disc on the blower problem and saw message that climate control did not have resistor pack - was wondering if there was a good how to for climate control fault finding.
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    There isnt a goog fault finder.. as they very selten fails... but when they do it will cost £££ to get it fixed.. probaly cheaper to get a new blower motor ect. and change that over...
    Jul 2006
    greenock
    All sorted – blower now working on all settings
    Took bottom section of motor off (quite a few torx screws behind the unit that you can’t see). Broke a few of the plastic clips that hold it up as they were brittle.
    Took off the silver control unit (with PCB inside it) and gave that a good squirt with switch cleaner). Motor unit slides out when you take the three screws off the bottom. Give the motor, brushes and spindle areas lots of squirts with switch cleaner and WD and it became noticeable easier to turn. Blew out crud with air duster canister and all back together again (not all bolts back).
    Jun 2006
    St. Helens,Merseyside
    nice to see its sorted bud.
  1. Engine Flooded
    By admiral_reliant in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2012, 18:41
  2. Heater blower only works in highest setting
    By David Schofield in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2009, 19:59
  3. Passenger footwell flooded???
    Last Post: 30th March 2008, 11:04
  4. A flooded gloucestershire
    By nph1 in forum General Chat
    Last Post: 27th July 2007, 22:04
  5. me car`s flooded arrrrrrrrr
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2007, 04:33
