Thread: Broken locking wheel nut key (HELP)
    Regular Member SEANYboi's Avatar
    Dec 2012
    Bourne end,high Wycombe
    5 Post(s)
    Vehicle : Vauxhall vectra
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Default Broken locking wheel nut key (HELP)
    Broke me locking key yesterday. Not got key number
    Anybody local have a locking nut remover, or the same key as me
    Thanks sean
    Aug 2012
    Scottish Borders
    Or get someone to weld a bold to it and then remove it. That's what they did to mine.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Do vauxhall not keep a master set ?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    try and belt a socket over it..
    http://www.halfords.com/webapp/wcs/s...egoryId_255216
    or get one of them.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Jun 2006
    St. Helens,Merseyside
    Dec 2012
    5 Post(s)
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Thanks fellas Ive seen all the stuff on eBay and seen various ways of removing locking nuts. But thought I'd try my luck on someone nearby having the same key or a nut remover. If not then I will go for one of these other options
    Dec 2012
    Benfleet
    Engine : 1.9CDTi 150
    don't bother with a universal removal tool, i tried several when i bought my car without the key. they all rely on reverse screwing onto the outside of the head, which with the vauxhall standard lockers doesn't work as they have a rotating ring on them.
    Go to your local VX dealer as they should have a master set, if your lucky they'll sit with you and go through the box trying them one by one. they can then order you a replacement, or if they are really helpful they'll let you remove them all and throw them in the bin!!
    i'm sure that they have an identification number on the head of the key, think its a really small box with a 2 didgit number in
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    If you are an AA or RAC member they have sockets to take them off. Just deflate the tyre and call them out.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Yip as above the outer part of the bolt spins how i got mine off was got someone to weld a bolt onto it with no damage to the wheel took him 5 mins to get it off.
  1. Help Wanted : Wheel locking key broken
    By Envy in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2012, 13:13
  2. Wheel Locking Nut Key Broken :(
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2011, 22:29
  3. Broken locking nut key
    By LJ sxi-nav in forum Suspension, Wheels & Brakes
    Last Post: 19th May 2009, 12:53
  4. broken locking nut key!!
    By shaneyboy in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2008, 02:13
  5. Broken locking wheel nut socket
    By Matt21385 in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2007, 09:45
