Results 1 to 10 of 10
Thread: fuel filter housing leaking
Hybrid View
    Aug 2012
    berkshire
    Default fuel filter housing leaking
    Hi guys,
    my 1.9cdti 150 has developed a diesel leak st the bottom sensor plug.
    How much am i looking to replace it and has anybody got a part number?
    Aug 2012
    berkshire
    Bump
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    got the same problem on mine last week so bought on ebay second hand £50 and job done here is the link I found one http://www.ebay.co.uk/itm/VAUXHALL-V...item1c30a8ab09
    Aug 2012
    berkshire
    Quote Originally Posted by dbgb25 View Post
    Thanks mate,ive just added it to my watch list and will buy it 2mor if a trip to the scrappy doesnt produce anything
    Regular Member AntSSSS's Avatar
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Year : 2008
    Mileage : 100k
    When was the filter last changed?
    there is a drain in the bottom of the filter housing - maybe loose?
    I am in Ashford Middlesex, PM me if you want it looked at - may be an ideal time to change the diesel filter at the same time.
    A
    Aug 2012
    berkshire
    The filter was only changed a few months ago.
    Its been leaking for a while and put it down to the drain/bleed screw at the bottom of the canister but after nipping it up it was still leaking.yesterday i had another look and the sensor splug at the bottom has a small amount of play and its leaking out of there.
    Its been leaking quite bad as the power steering fluid container is covered in it and its dripping onto the belly pan and onto the ground where i park.
    It would also explain the amount of fuel ive been using and trouble with the car cutting out when its cold
    May 2012
    UK
    Vehicle : Vectra C
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    I've had the same problem, I recommend getting it fixed sooner rather than later - I initially left my fuel filter thinking I'll get round to it later, I'm fairly certain the excess diesel helped to corrode my coolant pipe costing more than 3 times the cost of a new fuel filter!!!
    Mines a 150 cdti too, getting fed up of it tbh, back in the garage today for a new alternator (£255)
    Aug 2012
    berkshire
    got 1 today from scrappy for 20 and its in mint condition too.
    £225 for alternator?? mine went about 2 weeks after buying my car(private sale) and i fitted it myself at a cost of £90 and exchange of old unit
    May 2012
    UK
    Vehicle : Vectra C
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    Quote Originally Posted by diesel_carp View Post
    where did you get that deal from? is yours a cdti 150 too?
    Aug 2012
    berkshire
    i got mine from my local auto factors,i avoided the denso unit that came with the car as they are rubbish.
    Yeah i got a 150 too
  1. 1.9 Fuel filter housing?
    By Barlow in forum Vectra C / Signum Troubleshooting
    Last Post: 27th June 2012, 10:45
  2. oil leaking from filter housing
    By dicky3706 in forum Engine & Drivetrain
    Last Post: 30th November 2010, 11:01
  3. fuel filter housing
    By daddyjay in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 13:19
  4. fuel filter housing
    By babsandy in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2010, 14:11
https:www.vectra-c.comforumshowthread.php182705-fuel-filter-housing-leaking
diesel filter housing leaking 1.9cdti
vectra c diesel 150 fuel filter housing part number
vectra c 1.9 cdti fuel filter housing leaking
vectra cdti fuel filter leaking
why os my vectra c dripping diesel from filter housing
vectra c fuel filter housing leaking
vectra 1.9 diesel filter leak from bottom
