Results 1 to 10 of 18
Thread: rear right brake sticking
    Regular Member scottrp's Avatar
    CREWE
    Default rear right brake sticking
    Hi Everyone please help.
    Okay so I have had the car for 2 days and I have an issue where the rear right brake pad sticks and now everytime the wheel rotates it makes a rumbling (clunking) noise I have put a pic below as I am NOT mechanically minded at all so I don't know if any one can see if anything is wrong with it.
    CREWE
    also could someone tell me how to make the break unstick
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Possibly corroded sliders..... the two pins/bolts the caliper moves on..... removed from the inner face of the carrier, possibly hidden under rubber caps.
    East Ayrshire
    Trim : SRI XP1
    Are you sure it's a sticking brake and not a knackered wheel bearing?
    Try what handyandy suggested, if that fails it's going to be either the bearing (causes a rumbling sound) or a sticking caliper itself
    CREWE
    because im not mechanically minded if i was to take this to a garage how much roughly would it cost to have it fixed. and thanks for the fast reply
    East Ayrshire
    Trim : SRI XP1
    it depends whats wrong. If it's a sticking slider maybe £10-£20 (it really is an easy thing to do yourself)
    Wheel bearing i'm not sure, I'd hazard a guess at around £100-£150 maybe
    CREWE
    ok well il tell the garage its a good chance of being what you advised. wiith out sounding special which part is the slider
    East Ayrshire
    Trim : SRI XP1
    If you look at the caliper from the back facing the front of the car, the very top and bottom will have bolts going in (about 13mm I think) there will be wee rubber boots, the sliders are in there. It's a case of undoing those 2 bolts and sliding the caliper off then popping out the sliders. Stick in some grease (I use copper grease) pop them back in and push them in and out a few times. Then caliper back on, tighten up the bolts (they don't need to be overly tight, just a nip)
    CREWE
    okay great well il do this tomorrow morning when i have some day light. Again thanks for the fast reply
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The carrier (1) is the part mounted to the hub... contains the piston and remains stationary.
    The caliper (2) slides on two pins which screw in through the caliper.
    The anti-rattle spring (3) is just what it says.
    The pads (4 - part of one visible) are squeezed by the carrier and caliper against the rotating disc to slow it.
  1. rear pads sticking on??
    By nickp1975 in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2013, 07:28
  2. 1.9 CDTi rear caliper sticking
    By Tennants in forum Suspension, Wheels & Brakes
    Last Post: 14th October 2012, 13:06
  3. Rear brakes sticking (vectra)
    By Steve 100 in forum Handling & Braking
    Last Post: 6th July 2012, 08:05
  4. rear brakes sticking
    By eminemme42 in forum Suspension, Wheels & Brakes
    Last Post: 13th March 2012, 21:20
  5. sticking back brake.....
    By david.aka.judas in forum Suspension, Wheels & Brakes
    Last Post: 1st March 2009, 15:26
