Results 1 to 2 of 2
Thread: Powerflex gearbox / engine mounts - Vectra c and Signum
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Default Powerflex gearbox / engine mounts - Vectra c and Signum
    These are my spare Powerflex gearbox mounts.. Both are the same and both are needed for one car.. They fit over the existing lower bushes, one set for the front mount and one set for the rear mount. I did a trial fit on one of these on a vectra last month to show somebody it was the correct and all was good.
    Your standard rubber engine mounts start to break down after a while and cause excessive vibration which can be especially noticeable at start up. Once you start getting those squeaks and knocks you will can stop yourself oiling everything (don't oil rubber by the way, use silicone lube) which will just shorten their life.
    These are sold in two different types, pink for diesels (says it all really) and a nice yellow colour for petrols. However the yellow are stiffer and can induce added engine vibration so unless you are building a track car trust me on this and go with the pinkies for all others when fitting these mounts.
    You can fit these on your driveway with the car on axle stands, i have done a couple of fittings now.
    £40 for the pair COC or delivered.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    sold, payment received. thanks
  1. Powerflex engine mount bushes
    By Caveman_nige in forum Handling & Braking
    Last Post: 6th May 2012, 15:16
  2. engine and gearbox mounts
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2011, 19:35
  3. Help! Engine Gearbox Mounts 53-3.2 V6 GSI Vectra
    By garygsi in forum Engine & Drivetrain
    Last Post: 7th February 2011, 20:18
  4. Engine / Gearbox Mounts 2.2 DTI
    By MJL in forum Engine & Drivetrain
    Last Post: 20th October 2009, 12:43
gearbox mounting vectra c
gearbox mounts vectra c fitting
vectra c engine mount
signum powerflex
