Thread: heavy steering
    Mar 2012
    Walsall
    Default heavy steering
    My steering is driving me mad now.. it intermittently becomes incredibly heavy and seems to interfere with the return to straight speed of the wheel. Once it starts it will last for a few days, and seems to occur once the wheel is 90 degrees from straight and is becoming a pain in the ass when trying to turn. Initially I thought it would be the top mounts needing some greasing, but that doesn't seem to have solved it at all.. any other ideas that I should try..?
    East Ayrshire
    Trim : SRI XP1
    wishbone, cv joints? I've got the opposite just now, front end feels too light, replaced shocks, springs, mounts, drop links, os wishbone still no better. Things can be a pain in the hoop to find
    Mar 2012
    Walsall
    I've had new struts springs and drop links, so its nothing there..
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check the power steering fluid level. My first Vectra did EXACTLY that. Fluid was very low. Topped up and was fine thereafter
    Mar 2012
    Walsall
    As I understand it, that's a bit of a ****** to check isn't it..? I have a signum 2.2 direct..
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Not sure on the Signum. Mine was a 52 reg Vectra C 2.2 DTi. It was behind the driver's side front wheel arch liner
    Mar 2012
    Walsall
    Yep, same as on the signum i believe..
  1. Intermittent heavy steering?!
    By Chip in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2013, 00:51
  2. Heavy steering when cold
    By ldanieli in forum Suspension, Wheels & Brakes
    Last Post: 9th December 2012, 12:37
  3. very heavy steering
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 19:10
  4. Heavy steering intermitent
    By craigbarlow18 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2010, 00:32
  5. Steering heavy HELP !
    By cpt slow in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2006, 09:03
heavy steering on drivers side vauxhall vectra
