Thread: Corsa... Aerial lead missing!
    Chelmsford
    Default Corsa... Aerial lead missing!
    Hi chaps,
    Just sorting out a few niggles on a 1999 Corsa before it gets sold. (anyone want it by the way? It's in Essex)
    Known for ages the aftermarket radio didn't work (no AM or FM reception) so assumed it was a loose connection to the aerial. Just took it out and found there's no evidence of an aerial lead at all!
    Anyone know where on earth it might be and where it's likely to run? I've checked, there's very definitely a black sticky uppy thing on the roof!
    I assume I'm looking for a standard coaxial cable, but no sign anywhere!
    Cheers!
    Aug 2010
    Leeds
    I suspect there's a join somewhere in the coax you can plug a piece in.
    But why bother fixing it for the expense just sell it as is it's not going to get you mega cash working.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    on the left hand side under the trim theres another plug where the patch lead fits in i bet its dropped down or something
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If the Corsa is the same as a Vectra with a built in cage, it'll be a small round connector,not a shiny plug and you'll need an adapter to make it fit the stereo,they're only a couple of quid from everyones favourite place !
    Chelmsford
    Cheers for replies chaps,
    Took the glovebox and fished around until i found something that looked like a co-ax cable. Followed it through the dash and found it jammed under the headunit cage.
    Jun 2012
    lancashire
    Quote Originally Posted by DNS View Post
    lol when I lost sister in laws i was trying to use phone to get some light in there yep i then dropped me phone down the back of her dash
    Chelmsford
    Oops!
    Rather amusingly, when I was cleaning the engine bay up earlier I found something that had previously fallen off and was resting on top of the gearbox... The engine cover! Had the car for 6 months and always assumed it didn't have a cover at all! Amazed it was still there!
  1. Corsa C Alloy And Corsa D Grille
    By andy.l in forum Parts for sale
    Last Post: 6th May 2007, 12:46
  2. Aerial connector lead
    By raymie.d in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2007, 10:16
  3. CCR2006 aerial lead
    By AlexB in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2006, 16:18
