Thread: Uniroyal Rainsport 2 Tyre noise
    Regular Member Porl's Avatar
    Apr 2012
    Barnsley, South Yorkshire
    Default Uniroyal Rainsport 2 Tyre noise
    Hi
    Had my Uniroyals Rainsport2 on for a few thousand miles now. I am getting a load of tyre noise of them - so much so that I thought the bearings had gone when it first started!
    Had it checked out and serviced and the noise is still there. I like the tyre but hate the noise. Has anyone else had the same problem with them? I previously had the same tyre on my Mondeo ST and never had the same amount of noise (unless I could heard it over the diesel engine LOL!)
    Any thoughts?
    Paul
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Are they wearing evenly, could have some alignment issues causing them to wear unevenly and make some noise.
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Had these on my bora mate and didnt notice any excessive noise.
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Ive had these too, no noise with mine bud
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    i have these on mine in 235/35/19, and tbh they're fine....not too noisy , good grip and wear rate..
    13 Post(s)
    I've had Rainsport 2's for quite a while now, but it's only the latest ones fitted that started making a noise a couple of 1000 miles after being fitted. Only happens at approx 35 to 40 mph, which just so happens to be the average speed of my daily commute to work and back so I end up hearing the noise all the time.
    Previous Rainsport 2's have been fine. All this co-encided with ATS doing the tracking on my car. They said that 4 wheel alignment wasn't possible on my car so only adjusted the front wheels. I'm still getting inner tyre wear on my nearside rear tyre, but they said it's quite normal because of the camber set up of the rear wheels - I know they're talking rubbish.
    I spoke to the Vauxhall garage the other day about 4 wheel alignment who confirmed it can be done and if ATS tracked the front wheels by taking a reference point from the rear wheels (they used laser markers on all four wheels) then that's more than likely the problem with the tyre noise. If the rear wheels are out of alignment then using them to track the front wheels would also put them out too.
    In short, it's more than likely you'll need a 4 wheel alignment doing.
    Apr 2012
    Thanks for the replies.
    My noise is worst between 30 and 50 mph. Unfortunately I have just had a 4 wheel alignment done and I still have the noise. Think I will just have to keep an eye on the wear and hope that I can get used to it!!!
    LOL
    13 Post(s)
    You're probably stuck with the noise now until you replace the tyres as they have irregular wear because of the previous misalignment.
    WGAF#5
    Have you checked the tyre edges for feathering ?? Would look like buzz saw effect on the outer or inner edges ? This would sound just like wheel bearing drone ... Although I would have expected a decent wheel alignment centre to pick this up
  1. Uniroyal Rainsport 2
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 09:44
  2. Uniroyal Rainsport 2 @ Kwik Fit
    By big nath in forum Handling & Braking
    Last Post: 10th March 2011, 02:53
  3. Eagle NCT5 V Uniroyal Rainsport 2
    Last Post: 23rd February 2011, 17:11
  4. uniroyal rainsport 2's
    By chrissri82 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2009, 17:19
  5. Uniroyal Rainsport 2
    By chris fixter in forum Handling & Braking
    Last Post: 27th May 2009, 11:59
