Results 1 to 10 of 16
Thread: HID problems
    Regular Member IRMSCHER ALBA's Avatar
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    Default HID problems
    hi i have a problem with newly installed hids when i put on the hids without starting the engine no problem but when i turn them on with the engine running they flicker and eventually go off and a low beam warning comes up but if i switch off engine turn off hids turn them back on start engine no problem anybody know how to fix this cheers
    Dec 2011
    Seaham
    I think you will find the ballasts are on the way out? Do you have cancellers fitted or have you had the Xenon option switched on? The Xenon option can sometimes stop faults??
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    the hids are brand new and fitted with cancellers how do you switch the xenon option on i thought it might be the ballasts but they were checked and fine
    Northampton
    Engine : A20DTH
    Mileage : 88000
    you need to use software tech2/opcom/vauxcom
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    Default hids
    i have angel eyes fitted not sure if this makes any difference
    Dec 2011
    Seaham
    Angel eyes will not make any difference. Get someone to switch on the Xenon option, see if that sorts out the problems. I would do it if you lived closer.
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    Quote Originally Posted by Ben50n View Post
    thanks for the offer but yes i am quite a bit away thanks for the info
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    I could activate them for you if you want bud.
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    where are you about mate
    Apr 2011
    Las Vegas
    Just buy some hid cancelers. Worked for me
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  5. Got problems!!?
    By POOL MAN in forum Detailing and Car Care Discussion
    Last Post: 23rd June 2009, 22:06
