Results 1 to 10 of 19
Thread: Cd70 Navi
    Regular Member bopster's Avatar
    Sep 2011
    leeds
    Vehicle : vectra
    Trim : sri
    Engine : 150 cdti
    Mileage : 150k
    Default Cd70 Navi
    I've bought the cd70 navi for my vectra i have installed it but found the fm reception is appaling. I did notice the wire for the aerial had a 2 wire plug that goes near the interior light. Im unsure od the colour of the wires could these be live and earth for the aerial base?. I dont know what else the problem could be.
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    Mines factory fit (as far as I'm aware) and my fm reception is terrible sometimes! Constant hissing.... Bit disappointing they didn't put dab in the cd70 IMO
    Regular Member Craig1985's Avatar
    harwich essex
    Mines the same. Mine was worse with something charging is 12v socket, have you got anything charging?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Electonic interference always used to be most commonly down to a bad earth somewhere... bit more complex now with so much electronic equipment.
    If you have the OE GPS antenna base fitted then you should find a home for the dangling wires, although I'm not sure if the base also contains a signal amplifier.
    You could also check the aerial wire for shorting - being 'nipped/pinched' at some point maybe have damaged the insulation.
    In general though, bad earthing of the radio chassis was always high on the list when nearby electrical devices seemed to cause signal interference.
    harwich essex
    Ok that's for the tip, will try a running an extra temp earthy I the head unit
    Sep 2011
    leeds
    Vehicle : vectra
    Trim : sri
    Engine : 150 cdti
    Mileage : 150k
    I dont have anything charging in the car all the aerial wiring was in good condition. My cd30 was bad with reception but the cd70 is totally sh**e i can only get radio 1 and that is very bad.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Fair point ... Radio 1 has been awful for many years now
    Sep 2011
    leeds
    Vehicle : vectra
    Trim : sri
    Engine : 150 cdti
    Mileage : 150k
    Does anyone know what the wire is for that comes from aerial base and goes to the interior light but i dont have anything for it to plug in to?????
    harwich essex
    Mic? For the Bluetooth hands free???
    Sep 2011
    leeds
    Vehicle : vectra
    Trim : sri
    Engine : 150 cdti
    Mileage : 150k
    Im unsure 1 wire is blue with red tracer the other is black
  1. cd70 navi
    By vectra sri dan in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 14:47
  2. cd70 navi help please
    By davidlewis24 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2010, 20:10
  3. Navi CD70
    By Stephen S in forum Electrical & ICE (including SatNav)
    Last Post: 1st July 2009, 20:50
  4. Need help with my CD70 NAVI
    By Big Sie in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2006, 12:35
