Hi guys, just had my thermostat replaced am getting some heat but its just warm air coming through not very hot air. Doesn't heat the car up. And sometimes it just blows cool air. What could it be?
could be the motor that controls the direction of hot air and cold air, possible thermostat fail ?
Remove expansion cap.
turn heat upto full on heater an fans off
start car an run upto temp whilst pumping bottom rad hose.
chances are its just an air lock if its only been since thermostat change
how do I do this maaan. AM sooo cold lol. Can I do it by myself.
Hi guys the pumping didn't work. Any other ideas? someone please help me![]()
I'd have a look for ya if you wanna bring it over
i wouldnt have thought so fella the antifreeze mix would have to be seriously dirty to clog up a heater matrix... you either have a air lock or the controls for the heating aint working
When the engine is hot feel the two pipes to and from the heater they should be hot, if not you have a lack of flow through the heater rad, if hot, you may have to get under the dash (passengers side) and see if the heater flaps are moving through there full motion whilst moving the heater from hot to cold and back, have had a few motors fail and the gears break not allowing full movement.
